Is it possible to add a block of formatted text to a webmap popup using Arcade 'if/else' expression?
626
06-25-2019 09:59 AM
ZacharyBaron1
New Contributor III
Hello,
The map in question will be published through AGOL. I have a web map with a number of zones that are swept by a street sweeper. My goal is for the user to click on a given zone and get the schedule for that zone.  The schedule has been worked out for the next year and a half and each zone's schedule has been listed and formatted in text. Like this:
Route 11
This route is swept on the following Fridays between 3am and 11am:
Friday, June 7, 2019
Friday, July 12, 2019
Friday, August 16, 2019
Friday, September 20, 2019
Friday, October 25, 2019
Friday, November 29, 2019
Friday, January 3, 2020
Friday, February 7, 2020
Friday, March 13, 2020
Friday, April 17, 2020
Friday, May 22, 2020
Friday, June 26, 2020
Friday, July 31, 2020
Friday, September 4, 2020
Friday, October 9, 2020
Friday, November 13, 2020
Friday, December 18, 2020
This schedule may change if the sweeper truck is needed to respond to other situations like storms or accidents. The schedule may also be affected by holidays and staffing availability.
Please note that not every street in any given sweeper zone is swept. Only the streets highlighted on the map are included in the route. The most common reasons for streets not being included are either that they are private, or too steep, narrow or windy for the sweeper truck to maneuver."
What I would like to do is write an Arcade statement that says if the Route Id is 11 return 'This big block of formatted text'
else if Route ID is 8 return 'This other big block of text', etc, etc.
I believe the problem is the multi-line nature of the text. Is there any way around this?
I considered using a StoryMap and putting each zone/schedule in its own tab, but although a tab can link to a feature, a feature cannot open a given tab--at least not to my knowledge and not in AGOL. Maybe in Portal with custom code, but that is not available to me.
Thoughts?
Zak--
AndyShoemaker
Hi Zak,
You can certainly do this with arcade and an If/Else statement. The line breaks do make it a bit complex but it can be done like this:
"This route is swept on the following Fridays between 3am and 11am:" + TextFormatting.NewLine +
"Friday, June 7, 2019" + TextFormatting.NewLine +
"Friday, July 12, 2019" + TextFormatting.NewLine +
"Friday, August 16, 2019" + TextFormatting.NewLine
Personally, I like using the "TextFormatting.NewLine" and a line break so it is easier to get an idea of what the end product will look like. However, you could just simply keep everything on one line for simplicities sake (ie "This route is swept on the following Fridays between 3am and 11am:" + TextFormatting.NewLine +"Friday, June 7, 2019").
You can also take advantage of using variables for standard texts (like the disclaimer at the bottom). This could look something like this:
var route_11 = "Line 1" + TextFormatting.NewLine + "Line 2"
var standard_text = "Standard Disclaimer"
if($feature.RouteID == 11 ){
   return route_11 + TextFormatting.NewLine + standard_text
else{
   return standard_text
Cheers,
Andy
Andy Shoemaker
AndyShoemaker
Hi Zak,
else{
Cheers,
Andy
Andy Shoemaker
ZacharyBaron1
New Contributor III
Thanks Andy,
That did it for me. I tried the TextFormatting.NewLine earlier, but I forgot to concatenate it...
This is tedious, but once it's done, it's done and the popup will have all the information with no extra clicks.
Thanks again--
Zak--
