How to Traverse Points of Intersection - Tangent Distance, Delta Angle, and Radius
2575
02-25-2013 11:07 AM
JamiePetersen
I have an old survey-type drawing (pdf attached) for a street centerline that I would like to draw via COGO traverse.  It gives Points of Intersection, Tangent Distance, Delta Angle, and Radius in a table.  The legal description references phrases such as "thence N 79-29-30 W to the point of curvature (PC) of a curve... and to the point of tangency (PT)".  I'm struggling to get my COGO editing environment to produce results.  Anyone care to share their thoughts on how I should go about getting the centerline drawn?  Thanks in advance.
JamiePetersen
Ok - figured this out.  For reference, I used this formula along with the windows scientific calculator do convert between DMS and Degrees:
For Right-turns: 180 + Delta Angle
For Left-turns: 180- Delta Angle
This got me the vertex to vertex line, but I still haven't quite figured out how to do the actual centerline with curves intersecting points of tangency and points of curvature.
JamiePetersen
And the last piece of the puzzle is solved.
I used the Curve Calculator tool from the COGO toolbar to add the angle and radius, which gave me the tangent length.  Using the given tangent length, I created line segments extending out from the PI's.  Then I used the Arc Segement editing tool, snapped to the tangent length lines, then hit "r" key to enter the radius.  Done.
