How do I stay current with future releases of the Local Government Information Model?
2540
10-17-2012 06:05 AM
ScottOppmann
We recently got a question and thought it might be valuable to post it on the forum:
"We are moving our CAD based mapping to the ESRI Local Government Information model.  This process is well underway and I'm trying to get a handle on how we are going to manage change going forward.
What is the general approach to releasing ESRI Local Government Information Model changes going forward.  Can I expect to see upgrade wizards sort of like we see when a new release of a geodatabase comes out with a new release of ArcGIS?  I need to get a handle on how we are going to keep our 300+ LGIM compliant municipal clients, which will likely have data model customizations. current as updates are made to the LGIM by ESRI."
ScottOppmann
We are providing detailed release notes with each release of the local government information model and I would use these to guide your strategy.  I would not think about the quarterly releases as a �??compliance issue�?�.  Rather, I would review the maps and apps provided in the solution and decide which maps and apps you'd like to deploy and use that as a way to determine when/if you upgrade the information model.
We are not providing an upgrade wizard per se.  But, we are teaching users how to use subsequent releases of each schema and an Add-in called Xray for ArcCatalog to determine what changes exist (ex. compare your current schema to the new Local Government Information Model) and create a new schema that reflects the changes you�??d like to make.  Then you can create a new schema and work it through your dev, staging, QA and production deployment approach.
LeonScott
I've been trying device a workflow for upgrading my existing data in a previous version of the LGIM to a newer LGIM schema using X-Ray, just as were explaining.  I am running into an issue when I try to create to an updated schema  using X-Ray that preserves some changes that I made with the newer version of the LGIM.  I had expected when I used the 'Merge Into XML' then import that to a new geodatabase, it would include a combination of missing items from each geodatabase.  Instead it seems to have added the fields missing from one source, but not the other.   I was expecting the sum of the two.
I also tried to use the Import Using Geoprocessing tool, but it kept giving me an error on the domains.  The errors where "Domain Name: Value is required".  It appears that I somehow generated some XML with blank domains.
Leon
