Hi, I downloaded the executive dashboard from github, threw it on my webserver, clicked "sign in", entered my arcgis online credentials, and it logged me in, but gave me 7 javascript errors, all saying the same thing:
It displayed the progress bar, but never displayed any content.
I noticed that the live example located at http://localgovtemplates2.esri.com/ExecutiveDashboardTryItLive/ works just fine with the jsapi 3.1 so I copied all those javscript files over to my webserver and tried to run it, but it gave me the same 7 javascript syntax errors.
Any idea why this is happening or what I can do to get it working? I thought this application was supposed to work right out of the box. Is it failing because I have to provide links to my own map services?
Please review the help topic below and ensure you have configured the app correctly and deployed it on your web server completely. If you are still having trouble after you've reviewed the help topic, feel free to contact Esri Support Services.
No, you will have to configure the application with your ArcGIS Online group and webmaps and configure the application to work with this content. The try it live app is set up to work with sample data and named AGOL users Esri provides for evaluation purposes.
I recently deployed the 10.2. version of the Executive Dashboard.
I guess that the source code was for State government version since I have the Swipe -button in my app. Can I get it to work by configuring a webmap or in another ways?
Can I easily disable the mandatory login after the initial screen as my app is for demo purposes and the data is public?
To enable the swipe button in the Executive Dashboard, all you need to do is add the compare tag when authoring your map in ArcGIS Online. As for your question about disabling the mandatory log in, you cannot disable the log in.
