Hi, I am trying to find an appropriate dry cleaner icon to use on a web map. The best icon so far is a washer and dryer, which isn't really what is needed, as it dry cleaners do not use washer and dryers. If you have found a suitable icon (preferably ESRI), please respond. Thank you!
Cynthia,
I can't say I have seen one from Esri but something like this should work, I would think:
Adrian,
I really like this and did see it on the internet. Perhaps we will need to create something, as I cannot find an ESRI one either.
Thanks!
Hi Cynthia,
I don't see a dry cleaning symbol from Esri either. The closest I found might be the Department Store icon the ArcGIS Explorer Style:
Here's also a link to the ArcGIS Symbol Library. Though this is very old, it might be a good document to look through, just to check?
I hope that helps! If I find anything else, I'll pass it along!
-Lauren
Thank you Lauren,
I like the department store clothing, but it may be too complex. I have already looked through and searched through each of the symbols in the ESRI Library.
Thanks again!
Hello,
I'd take a look at: Noun Project - Icons for Everything
