Contour Index
554
07-26-2013 07:45 AM
PatriciaMoehring
Can someone tell me what the Contour Index is supposed to represent?  It is either 0 or 1 and how topo lines are symbolized in the template.  Thanks, Patricia
AlanToms
The index contour is there to help certain elevations stand out so it is easier to read.  For example, I have 1ft contour feature class.  Any contour with an elevation divisible by 5 I have as my index contour.  As far as symbology, just make them a little bit different so they stand out; thicker lines, different dash lengths.
Alan
HeatherEisan1
Contour Index is (like Alan mentioned) is a thicker symbolized line and is usually labeled with the elevation that it represents. Depending on the contour interval it may be every fourth or fifth line. 0 represents the contour index while 1 represents the contour interval which is the contours between the contour index. Contour interval will be symbolized with a thin line and it will not be labeled.
