WFS Works in Gaia but not in ArcCatalog
2776
11-20-2011 11:16 PM
LionelSlade1
I have a WFS service which is working fine with Gaia, but not at all with ArcCatalog.  In ArcCatalog it lists the two layers under the Table List, but does not display any data.  It  only gives one Layer as 'No Geometry' under the tree view beneath the connection.
Where to start looking??
TIA
Lionel Slade
TonyContreras
You can check the Data Interop logs-
Windows XP:
C:\Documents and Settings\<login name>\Application Data\ESRI\Interoperability\logs
Windows Vista:
C:\Users\<login name>\AppData\Roaming\ESRI\Interoperability\logs
The messages there may be hard to filter through, but the information is probably in there. You can also use a utility called "Fiddler" to monitor the requests to the service. It will show the request sent to the service and the response that it returns. In Gaia, right click on the properties of the layer, and it should have a "Query" tab that shows the request it is making (for comparison).
