Spatial Statistics Analist
201
01-21-2021 10:25 AM
AntonioBarreto
Hi there,
i´m having trouble usin spatial statistics tools. When i go from arctoolbox and try to use any of the analizing patterns tools nothing happens, and if go from the search menu the message i receive is "Adding this item is not supported or the application that opens it is not present".
How can i solve this?
Thanks
DanPatterson
MVP Esteemed Contributor
Are you using arcmap? or arcgis pro?
Is your license enabled in arcmap? (Customize menu, extensions)
Was it enabled for Pro?
... sort of retired...
