Dear Community,
i want do some spatial statistics with the space-time-pattern mining (definied Postions, stations Data)
I want to create a new feature class. So of course all the stations datas have the same coordinate.
Should i create a Z-values? And whats my coordinate system...
After that i want to connect it with other attribute tables with the station information and create after that the space time cube.
Thanks forward!
Greetings,
Andrea
XY Table To Point (Data Management)—ArcGIS Pro | Documentation to create a point featureclass with X, Y and Z values
You have to know the coordinate system. Do the X, Y values look like they are in decimal degrees? or in a projected coordinate system
Have you seen the requirements and discussion on space-time cubes? Does your data meet the requirements for multiple time slices?
Visualize the space-time cube—ArcGIS Pro | Documentation
Hey Dan,
thanks for your answer...
Yes i have the seen the requirements and your Link https://pro.arcgis.com/en/pro-app/latest/tool-reference/space-time-pattern-mining/visualizing-cube-d...
...but i have measuring datas (station datas)...so it should fit with space time cube with defined positions or not?
My coordinates are in Gauss-Krueger and also Longitude and Latitude...
Thanks forward!
Greetings,
Andrea
This option Create Space Time Cube From Defined Locations (Space Time Pattern Mining)—ArcGIS Pro | Documentation
mentions station data explicitly and you need an attribute and your data should represent time slices. I am not sure what you are working with so perhaps others may weigh in.
It is just like that https://pro.arcgis.com/de/pro-app/latest/help/mapping/time/temporal-data-in-separate-tables.htm
like the one to many table...
so i think it should work...
Greetings,
Andrea
