Hi all,
Whenever I try to run the Hot Spot Analysis (Getis-Ord Gi*) tool, I find an error icon of red circle with a cross inside, on the extreme top left and next to the Input Feature Class. The circle is found as soon as the tool window opens and even before I put in anything.
If I ignore this icon, put int eh required parameters and click OK, an error window appears, just containing a yellow triangle with an exclamation mark inside.
Can any one please advise how I can overcome this problem. I assume there might be some problem with the software settings, but not sure what is causing this conflict.
Best regards.
