Hello,
I wanted to suggest adding the ability to change processings settings at the organization level.
Currently output and processing settings can be set at the mission level or the project level, but we have some clients who require their images to be processed in the same way for all of their projects and with the settings only at the project level it means they have to remember to go in and set them for each individual project before uploading images and processing. However if they could set it at the organiziation level than all their projects could be processed the same without further adjustments.
Thank you for your consideration.
