Site Scan: Live video feed issue
402
02-13-2022 10:09 PM
JohnHughson
I have encountered an instance of a user whose Site Scan is not enabling the viewing of the live video feed since receiving the update last week.
They have tried this using two drones (DJI Matrice M200 v2), and two iPads.
Can also confirm that the camera works as the DJI monitoring screens are functioning.
I cannot find any other mention of this issue, so I am asking whether anybody has encountered a similar error as of yet?
NicoBonnafoux
Hi @JohnHughson
What sensor(s) are you using on your M200 v2?
Please confirm that your iPads are running the latest version of iPadOS.
JohnHughson
Hi @NicoBonnafoux,
I hope the below information is useful.
  • iPad model: A1822,
  • iPad OS: 15.3.1 (up to date)
  • Site Scan Flight for ArcGIS  version: 4.3 (up to date)
  • Drone (DJI Matrice V2)
  • Camera used: X-4S Camera
  • Sensor: Only the above camera
  • RTK / PPK: Not running RTK or PPK. They do not run PPK through sitescan.
  • Mode being used: Have only ever used Area Survey Mode
  • Make sure all other drone software is closed on iPad. No other Software open at all: Site Scan is the only drone software they have on these iPads.
  • Try different USB cable to controller: They’ve done this between 2 drones, 2 iPads, 2 cables.
Regards,
NicoBonnafoux
Hi @JohnHughson
I see no reports of a similar issue, and our flight test team also tested this configuration without issues. Please file a support ticket through Esri Technical Support, and a support analyst will reach out to help find a resolution.
Regards,
Nico
