DJI Matrice 210 V2 and Site Scan LE
487
10-19-2021 09:32 AM
RodneyJackson1
Has anyone used the Site Scan LE app for a waypoint or inspection mission with the DJI Matrice 201 V2?
In addition to setting the height for pausing the craft before initiating manual flight inspection control, is there way to modify the auto take-off speed?  Can control (e.g., use of pause RC button) be enabled before the craft reaches the assiganed pause altitude. This might be necessary in areas with unexpected air-traffic, for example.
I am using an iPad Pro, 14.6 with the DJI Cendence controller. Thanks!  Rod
NicoBonnafoux
Hi @RodneyJackson1 ,
The DJI Matrice 210 v2 is supported in the Site Scan Flight app and Site Scan Flight LE.
There is no "waypoint" flight mode perse in the Site Scan Flight app at this time, though many users will user either use the Vertical or Corridor Scan flight modes for inspection purposes, in addition to the manual Inspection flight mode you referenced.
There is no option to adjust the auto-takeoff speed in Inspection mode, but you do have the option to take off manually so that you can control the takeoff speed yourself.
During any autonomous operation with the Flight app, you can always regain manual control by moving the drone's flight mode switch out of "P" (Position) mode, this switch is located in the DJI remote controller.
Regards,
Nico
NicoBonnafoux
Regards,
Nico
