Robert's Flex Viewer Widgets Questions
Search instead for
Latest Activity
Sort by:
POST
I have a table that has 3 time ranges for Monday. Using the eSearch widget, how do I write an expression to show who ...
CollinHorace
by CollinHorace New Contributor II
0 6
3534
POST
I am trying the cemetery management with Arcgis Viewer for flex,I add relationships in ArcMap and publish to ArcServe...
0 0
POST
Hi Robert I' m using your IdentifyWidget and onprivate function widgetOpenedHandler(event:Event):void {//my add to sa...
NatashaManzuiga
by NatashaManzuiga Occasional Contributor
0 0
POST
Greetings,I am trying to publish a GP within Flex Viewer but it says: Could Not Determine Geoprocessing Execute Type....
JoseBarrero1
by JoseBarrero1 New Contributor II
0 0
POST
I have built application with Flex 3.7 and using enhanced search widget, I want to show related table. The relate ico...
NaseerShafique
by NaseerShafique New Contributor II
0 9
3061
POST
I know how to bring layers into the Flex Viewer turned off or on. But, I have 50 layers in one map viewer. Some are o...
TimHayes
by TimHayes Regular Contributor
0 3
POST
Hello,Is there a way to define the popup layout to be rtl?thank you,Roi.
roialgavish
by roialgavish New Contributor III
0 0
POST
Hi Robert,Using your ID widget 3.7 for Flex, I am having trouble getting a layer in a service excluded from ID widget...
BarnabyRockwell
by BarnabyRockwell Regular Contributor
0 1
POST
Can anyone tell me how to clear out the directions widget to enable a new direction to be entered without having to r...
0 2
POST
Here is what I would like to do:When a user turns on one specific layer, I would like a pop up box to appear in the m...
TimHayes
0 0
