eSearch - Searching Time Ranges
4256
6
04-14-2016 07:39 AM
CollinHorace
I have a table that has 3 time ranges for Monday. Using the eSearch widget, how do I write an expression to show who is available, based on user input. I am using military time and can successfully query the data in ArcMap with the following query:
(Monday_Range1_Start_Time >= 1900 AND Monday_Range1_End_Time <= 2400) OR
(Monday_Range2_Start_Time >= 1900 AND Monday_Range2_End_Time <= 2400) OR
(Monday_Range3_Start_Time >= 1900 AND Monday_Range3_End_Time <= 2400)
How can I get the same results within eSearch. Any help would be greatly appreciated. Thanks
RobertScheitlin__GISP
Collin,
  What type of field is the "Monday_Range1_Start_Time" and the 2 and 3?
CollinHorace
Hey Robert,
Those are (numeric) long integer fields. Thanks for the quick reply.
Collin,
  So in that case you would use the Between operator when configuring that search expression value.
CollinHorace
Can you please provide an example? It would be nice to only have 2 value prompts. A prompt for start time and one for end time that takes into account the six different fields. Or would  I need multiple expression values. I am just not sure.
Collin,
I am sorry. I did not even pay attention that you asked this about the Flex version o my eSearch. The Flex version does not have a between operator. I have not really touched Flex in a year so I am really out of touch with it. Do you need the 1900 and 2400 to be user input that can be changed?
CollinHorace
I don't mind using web appbuilder, if the function is there. I will give it a try, but still may need help with the expression. I will make another post in that subject area. Thanks for your help.
