Robert's Flex Viewer Widgets Questions
Latest Activity
Sort/Filter :
POST
Sir,using your Flex Viewer e-search widget 3.7Want to add calendar on date filed instead of date value to be entered ...
TasadduqHussain
by TasadduqHussain New Contributor III
in Robert's Flex Viewer Widgets Questions Last Updated 09-29-2021
0 0
POST
I have a table that has 3 time ranges for Monday. Using the eSearch widget, how do I write an expression to show who ...
CollinHorace
by CollinHorace New Contributor II
in Robert's Flex Viewer Widgets Questions Last Updated 04-14-2016
0 6
4258
POST
I am trying the cemetery management with Arcgis Viewer for flex,I add relationships in ArcMap and publish to ArcServe...
fakeryilmaz00fakeryilmaz00
by fakeryilmaz00fakeryilmaz00 New Contributor
in Robert's Flex Viewer Widgets Questions Last Updated 04-09-2016
0 0
POST
Hi Robert I' m using your IdentifyWidget and onprivate function widgetOpenedHandler(event:Event):void {<!-- -->//my add to sa...
NatashaManzuiga
by NatashaManzuiga Occasional Contributor
in Robert's Flex Viewer Widgets Questions Last Updated 08-14-2015
0 0
POST
Greetings,I am trying to publish a GP within Flex Viewer but it says: Could Not Determine Geoprocessing Execute Type....
JoseBarrero1
by JoseBarrero1 New Contributor II
in Robert's Flex Viewer Widgets Questions Last Updated 07-27-2015
0 0
POST
I have built application with Flex 3.7 and using enhanced search widget, I want to show related table. The relate ico...
Anonymous User
by Anonymous User Not applicable
in Robert's Flex Viewer Widgets Questions Last Updated 06-25-2015
0 9
3349
POST
I know how to bring layers into the Flex Viewer turned off or on. But, I have 50 layers in one map viewer. Some are o...
TimHayes
by TimHayes Regular Contributor
in Robert's Flex Viewer Widgets Questions Last Updated 08-16-2015
0 3
POST
Hello,Is there a way to define the popup layout to be rtl?thank you,Roi.
roialgavish
by roialgavish New Contributor III
in Robert's Flex Viewer Widgets Questions Last Updated 04-21-2015
0 0
POST
Hi Robert,Using your ID widget 3.7 for Flex, I am having trouble getting a layer in a service excluded from ID widget...
BarnabyRockwell
by BarnabyRockwell Regular Contributor
in Robert's Flex Viewer Widgets Questions Last Updated 05-07-2015
0 1
POST
Can anyone tell me how to clear out the directions widget to enable a new direction to be entered without having to r...
OCSFountains
by OCSFountains New Contributor
in Robert's Flex Viewer Widgets Questions Last Updated 02-11-2015
0 2
2 Subscribers
