Reference site for management of bridges and structures in ArcGIS?
411
11-13-2018 02:55 PM
FranMarsh
New Contributor II
I know many government agencies and DoTs use ArcGIS for collection and sharing of bridge inspection/maintenance and attribute data, but the examples I've seen all appear to interface with a separate Bridge Information/Management System.
Does anyone know of any agencies using ArcGIS to manage bridge, culvert or other structures directly as a standalone solution, with either ArcGIS or a third party interface for the reporting component? We have a bespoke legacy system for structures management with a relatively simple database structure that looks like it might translate fairly easily to the ArcGIS environment. Any reference sites for structures management in ArcGIS, or other feedback would be much appreciated. Thank you.
Reply
DerekLaw
Esri Esteemed Contributor
Hi Fran,
I'm not sure if the organization is just using ArcGIS stand alone - but they do use ArcGIS to create reporting apps.
Iowa Bridges StoryMap
Iowa DOT Bridges Dashboard
Hope this helps,
FranMarsh
New Contributor II
Thanks Derek
Reply
deleted-user-UxcAu2PHrDQp
Bridge data is managed with Bentley Inspectec but we pull the data from them and merge it with clearance data from Roads & Highways to create the data set using FME.  You can find the data at data.iowadot.gov
FranMarsh
New Contributor II
Thanks Eric
Reply
