Publishing R Script tool to Enterprise Portal as Web Tool
1074
12-08-2020 03:07 PM
DylanMurphy
New Contributor II
Has anybody attempted to publish a script tool created in R using the R-ArcGIS Bridge as a Web Tool before? A Web Tool I am working on relies on a R Script tool as part of the model. The model and the script tool itself both run successfully in ArcGIS Pro with no issues.
In testing this out, I have published the standalone script tool to my organization's Portal and, while it publishes successfully, when I attempt to run it within the portal it fails
My assumption is that I might need to install R, and the packages/dependencies used by the tool, onto the federated server that our Portal runs on. But, as someone relatively new to Enterprise and Web Tool publishing, I could be wrong about this. If I do need to do this, I would appreciate any advice on how to do so, as I am anticipating the package/dependencies transfer process might be a headache.
Does anyone in the community have any insights into this process and/or experience sharing an R Script tool as a Web Tool in Portal? Any help would be appreciated greatly - this is something I have been stuck on for a while now.
by Anonymous User
Not applicable
Hello Dylan,
I realized I answered this question in the Enterprise channel and adding my response here for completeness.
You are right, you need R on the server so that once your script tool makes R calls, it has access to the R interpreter.
We have seen some issues with timeouts lately, you may want to increase the timeout time limit in your portal. R can be notoriously slow and this results in a tool that just does not do anything in the portal, where in reality it just cannot finish and times out.
The most streamlined way of sharing the R web tool is creating a script tool in ArcGIS Pro and sharing it, it seems that is exactly what you have done.
Orhun
by Anonymous User
Not applicable
Hello Dylan,
Orhun
by Anonymous User
Not applicable
Orhun,
While it may be relatively simple for someone versed in Enterprise. I have tried setting up R by following Esri Deploying R in Server instructions using the r config point file. When i run my GP Tool, i receive an error to go install R. Does Esri have further images and guidance that can help?
