Has anyone tried to integrate R with ArcGIS Dashboard?
874
12-13-2022 08:14 PM
pat_algura
We're looking at utilizing some R capabilities that aren't supported with out-of-the-box widgets from Dashboard. Is this possible? We've seen it's possible with WAB, but we also still want to use the existing dashboard capabilities.
Patricia
AdamR
We've done it with WAB; mainly for integrating newer widgets (two customs) without updating the stack.
Since we're currently migrating to 3.0.2 and updating R to 4.2 at the same time we're investigating this functionality soon for Dashboards. The general consensus is to try updating the widgets and dump them in the server-dashboard widget folders.
You could also look at using Pro to create an R service that you could host on your portal, then use JS (probably? maybe Python API) to hit it for R work (kinda like the geoprocessing service) - https://github.com/RetailScientifics/Esri-R-Integration#creating-a-blank-web-appbuilder-app
