Apply Symbology From Layer works in geoprocessing but not modelbuilder
760
04-02-2021 01:18 PM
Labels (3)
Barty
New Contributor II
Hey all,
So when Applying Symbology from Layer template in modelbuilder it does not work (model runs fine but output shapefile doesn't take the template). But taking the same output shapefile (GLAHF_Merge_%Value%_polygon) and running the tool in mapview works perfectly with the exact same parameters. Any ideas why this is happening?
JayantaPoddar
MVP Esteemed Contributor
The symbology is saved in a layer file (*.lyrx), not in a shapefile.
Do a Save a Layer File  before applying symbology from layer. These layer files will be the input layer for apply symbology from layer. The input layer files' symbology will get changed.
Think Location
