Text next to PictureMarkerSymbol
964
11-23-2017 06:46 AM
DarkRider
Hi!
I am using ArcGIS SDK 100.1.0 Qt.
I want to create a PictureMarkerSymbol with a text label next to it. This text symbol will be updated during runtime with. I've tried to create a CompositeSymbol consisting of a PictureMarkerSymbol and a TextSymbol. However, the Text overlaps with the picture symbol. Is there a way to give the text symbol some offset to the picture symbol or is there another way to achieve this?
Thanks in advance
LukeSmallwood
Hi there,
You should be able to give the text symbol an offset using the "setOffsetX" or "setOffsetY" methods: MarkerSymbol Class | ArcGIS for Developers. They are defined on the base type MarkerSymbol rather than on TextSymbol
I hope that helps,
Luke
LukeSmallwood
Hi there,
I hope that helps,
Luke
