Label Item disappears from the scene after constantly calling setText()
1602
09-20-2023 01:14 AM
FatmaAkdemir
We have a label item showing the info about a track on the 3D SceneGraphicsView, just as below. There are many tracks on scene and each track has its own label.
Esri::ArcGISRuntime::Graphic *mpLabelItem = nullptr;
Esri::ArcGISRuntime::TextSymbol *mpTextSymbol = nullptr;
mpTextSymbol = new TextSymbol("", QColor(Qt::white), 10.0, HorizontalAlignment::Center, VerticalAlignment::Bottom, this);
mpTextSymbol->setOffsetX(10);
mpTextSymbol->setOffsetY(10);
mpLabelItem = new Graphic(Point(0, 0), mpTextSymbol, this);
QString labelStr(GetSource());
labelStr.append("-label");
mpLabelItem->attributes()->insertAttribute("source", labelStr);
mpLabelItem->attributes()->insertAttribute("id", pId);
mpMapViewer->AddToTracksOverlay(mpLabelItem);
However when we try to set text of this textSmbol once in every second, we face the problem of all labels disappearing from the scene after one day.
void PpiTrackItem::SetText()
QString mText = QString("T").append(attributes()->attributeValue("id").toString());
mText.append("\n");
mText.append("R:");
mText.append(QString::number(AstrxUnitConverter::ConvertMeterToNM(attributes()->attributeValue("range").toDouble()), 'f', 2));
mText.append("nm ");
mText.append("B:");
mText.append(QString::number(attributes()->attributeValue("bearing").toDouble(), 'f', 2));
mText.append("\u00B0");
mText.append("\n");
mText.append("S:");
mText.append(QString::number(Calculations::CovertMsToKnots(attributes()->attributeValue("speed").toDouble()), 'f', 2) + " knot");
attributes()->replaceAttribute("text", mText);
mpTextSymbol->setText(mText);
Tags (1)
GuillaumeBelz
Hello Fatma,
I tried to reproduce your problem, with a map and a scene, and 50000 text symbols in graphic overlay. Everything looks good.
Can you share a code and procedure to reproduce this problem?
Thank you.
FatmaAkdemir
Hi @GuillaumeBelz ,
Thanks four your reply. In order to reproduce the problem, you might change the text of those 50000 symbols once in every second indefinitely. It might be a while loop or a QTimer. Setting the text of the symbols with random text would be enough.
GuillaumeBelz
Hello,
I tried with a new 3D project with C++/Widgets API, on Mac and Windows, with version 200.2, but I can't reproduce the problem.
m_graphicsOverlay = new GraphicsOverlay(this);
m_sceneView->graphicsOverlays()->append(m_graphicsOverlay);
constexpr int N =1000;
for (int i = 0; i < N; ++i)
    Esri::ArcGISRuntime::TextSymbol* m_symbol = nullptr;
    m_symbol = new TextSymbol("a symbol", QColor(Qt::red), 10.0, HorizontalAlignment::Center, VerticalAlignment::Bottom, this);
    m_symbol->setOffsetX(10);
    m_symbol->setOffsetY(10);
    m_graphic = new Graphic(Point(randInRange(10000), randInRange(10000), 10000000), m_symbol, this);
    m_graphic->attributes()->insertAttribute("source", "text in attribute");
    m_graphic->attributes()->insertAttribute("id", 1234);
    m_symbols.push_back(m_symbol);
    m_graphicsOverlay->graphics()->append(m_graphic);
QTimer *timer = new QTimer(this);
connect(timer, &QTimer::timeout, this, [this]()
                m_symbols[i]->setText(QString::number(randInRange(100000)));
timer->start(1000);
Can you add more details to reproduce this problem?
 - Which version of SDK?
- How many symbols?
- How long to wait to reproduce the problem?
Thank you
FatmaAkdemir
Hi @GuillaumeBelz ,
We observe the problem after 24 hours of the executable up and working. There are approximately 200 symbols on the view. And version of the SDK is 100.8.
GuillaumeBelz
Hello,
I'm running a 24 hours test to check if I can reproduce the problem (200.2, Windows).
There was a known issue before 100.14 with memory leak in symbols. Maybe it's related. Did you tried an updated version of SDK (last version is 100.15)? Did you see a memory leak?
EDIT: I ran this test more than 30 hours (Windows, 200.2) without problem. It looks like it's specific to an old version of SDK.
