How to connect an arrow with the border of graphic object?
717
01-15-2018 05:09 AM
GeorgeArnaut
I created dynamical display by using arcgis pro sdk and I show the connections between nodes. For this I used an arrows (I'm use ArcGIS 100.2), the arrows connected with the centers of objects, but I want that arrows would be connected with the borders of objects!
Is it possible to do that?
LucasDanzinger
Esri Frequent Contributor
Hi George, is your screenshot of the existing behavior? If so, can you post a mockup of what you are wanting to happen?
