Get the list of Graphic items on a clicked point
1179
06-02-2021 05:56 AM
FatmaAkdemir
Is there a way to understand that user clicks on a specific Graphic on the map?
Nicholas-Furness
Yep. If you want to know for a specific GraphicsOverlay, you can call GeoView.indentifyGraphicsOverlay() and pass in the graphics overlay in question. If you want to consider all the GraphicsOverlays in your MapView, you can call GeoView.indentifyGraphicsOverlays().
There are also overrides that allow you to specify a max number of results to return. See the full list here.
Nicholas-Furness
FatmaAkdemir
Hi @Nicholas-Furness ,
I managed to get the clicked Graphic by using the method you suggested. However I am getting segmentation faults while dynamic casting the Graphic to the class that inherits the Graphic.
mpSelectedRulerNode->setGeometry(destinationPoint);
Even if I don't make any dynamic_cast, above code causes a SEGFAULT.
by Anonymous User
Not applicable
Hi Fatma,
Are you able to post any code that recreates this issue, or a crash-dump? I suspect that either  `mpSelectedRulerNode` or `destinationPoint` are being used after deletion.
