Anomalous behavior when scaling military symbols (APP6D)
536
12-13-2023 03:39 AM
Guglielmo_Cordasco
I would like to report an anomalous behavior when using APP6D symbology (app6d.stylx) in the ArcGIS Maps SDK for Qt 200.2. When applying the setScaleExpression function to the DictionaryRenderer, I am experiencing incorrect positioning of some amplifiers, such as the Direction. I have attached a screenshot with a scale set to 2 for reference.
Interestingly, in ArcGIS Pro, the scale function correctly positions the amplifiers.
Is there a solution to resolve this issue?
Thank you,
Guglielmo
Tags (3)
LucasDanzinger
Esri Frequent Contributor
Thanks for reporting this. We gave it a look and can confirm you've run into a bug with the scaling in 3D. I've logged the following bug - BUG-000163776 Dictionary Renderer Expression scaling renders incorrectly in 3D. If you would like, you can contact support to have your customer account number attached to the bug to receive status updates.
