Writing Geometry to Records with Empty Geometry Based on Matching IDs
1786
16
02-21-2020 07:38 AM
deleted-user-PUOLzzPmi8Uz
I have a polyline feature class with a related table attached. Is there a good way to write the feature class line geometry to the records in the related table? Goal is to create a feature class with lines with duplicate geometry, e.g. stacked. Any py code out that can accomplish this?
Thanks!
DavidPike
MVP Frequent Contributor
import arcpy
inFC = #path toExample.gdb\Lines
inFields = ['ID', 'SHAPE@', "Shape_Length"]
valueDict = {r[0]:r[1] if int(r[2])!= 0 for r in arcpy.da.SearchCursor(inFC, inFields)}
print(valueDict)
with arcpy.da.UpdateCursor(inFC, inFields) as cursor:
    for row in cursor:
        row[1] = valueDict[row[0]]
        print(row[1])
        row.updateRow(row)
my dictionary comprehension might be wrong, I always get confused doing them.
the rest miiiight work..
DavidPike
I dont quite get what you want to achieve, can you give more detail? Geometry objects can be accessed with a search cursor and SHAPE@
Hi David. Thanks for the quick reply. Essentially, I have a polyline feature class that contains records with geometry and without geometry. Records with geometry are related to those without geometry (Shape_Length = 0) by an ID. Thought it might be easier to break those no geometry records out to a related table, but now I am thinking it would be easier and more straightforward not to do that and just have a cursor write geometry to no geometry records based on matching IDs it encounters in the attribute table. Please to see below table.
DavidPike
Yep I'd recommend that. Let me know if you need a hand with the script.
I thought you meant a related table 'joins and relates'.
Thanks David. Yeah, was able to cobble together so py code and create a data dictionary. From there, not sure how to write the SHAPE@ to the records with NULL Geometry based on the matching ID that has Geometry. Any help/guidance is much appreciated. Thanks!
import arcpy
inFields = ['ID', 'SHAPE@']
valueDict = {r[0]:(r[1:]) for r in arcpy.da.SearchCursor(inFC, inFields)}
print(valueDict)
with arcpy.da.UpdateCursor(inFC, inFields) as updateRows:
    for updateRow in updateRows:
        keyValue = updateRow[0]
        print(keyValue)
        if keyValue in valueDict:
            updateRow[1] = valueDict[keyValue][0]
            print(valueDict[keyValue][0])
            updateRows.updateRow(updateRow)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
DavidPike
import arcpy
print(valueDict)
    for row in cursor:
        print(row[1])
        row.updateRow(row)
Thanks David. I got snippet to update the geometry, but unfortunately it only takes the first geometry and applies it to the rest of the non-geometry records. Thinking there needs to be a where clause that says if ID = ID and has geometry, apply geometry to non-geometry records with same ID. Anyways thanks a look. I appreciate the help. I'll keep at it!
import arcpy
inFC = #".\Example.gdb\Lines"
fields = ['SHAPE@','Unique_ID']
#Update cursor
with arcpy.da.UpdateCursor(inFC, fields) as cursor:
    #Set up dictionary to store previous non-null non-empty values
    lastNonNullVals={}
    for field in fields:
        lastNonNullVals[field]="" #set a starting value for each field
    for row in cursor:
            #Check if the current cell is null or empty
            if row[fields.index(field)] in [None,"", " "]:
                #Check if the previous value for the field exists
                if lastNonNullVals[field] not in [None,"", " "]:
                    #Set the cell to the previous non-null non-empty value
                    row[fields.index(field)]=lastNonNullVals[field]
            else:
                #if there is a value for the cell, set it so it can be used in the next row(s)
                lastNonNullVals[field]=row[fields.index(field)]
        cursor.updateRow(row)
DavidPike
I can't see why it's doing that. Could you show the prints or resend the feature as it wouldnt open in arc
Here is the feature class.
DavidPike
Wifi down so back to phone.
The last line in my previous should be cursor.updateRow(row)
