write contents of CSV to body of email
24373
18
12-16-2016 08:04 AM
jaykapalczynski
Honored Contributor
I am trying to write the contents of a csv to the body of an email and of course having issues.
I can list out the contents as such.  But looking for a formatted HTML version that I can place in the body of an email...I have been through a dozen of forums and cant seem to find a simple solution and one that works..
        csv.register_dialect(
            'mydialect',
            delimiter = ',',
            quotechar = '"',
            doublequote = True,
            skipinitialspace = True,
            lineterminator = '\r\n',
            quoting = csv.QUOTE_MINIMAL)
        print("\n Now the output from a dictionary created from the csv file")
        with open('z_outFileRegion1.csv', 'rb') as mycsvfile:
            dictofdata = csv.DictReader(mycsvfile, dialect='mydialect')
            for row in dictofdata:
                print(row['region']+"\t "+row['county']+"\t "+row['ramp'])‍‍‍‍‍‍‍‍‍‍‍‍‍‍
I tried this one but cant get it to work
python - Send the contents of a CSV as a table in an email? - Stack Overflow
Python send email from a csv list - Stack Overflow
Anyone have any easy solution to grab the CSV, format with HTML and attach it to the body of the email?
Below I am attaching the csv to the email but want to display the records in the email itself.
    filename = "z_outFileRegion1.csv"
    f = file(filename)
    #===BUILD EMAIL========================================
    def msgEmail():
        msg = MIMEMultipart()
        #body = "This is the message"
        #content = MIMEText(body, 'plain')
        #msg.attach(content)
        attachment = MIMEText(f.read())
        attachment.add_header('Content-Disposition', 'attachment', filename=filename)
        msg.attach(attachment)
        msg['Subject'] = "Region Report " + CurrentDate
        server = smtplib.SMTP('smtp1.fff',25)
        server.set_debuglevel(1)
        server.ehlo()
        server.sendmail(FROMADDR, TOADDRS, msg.as_string())
        server.quit()
    #===PROCESS EMAIL======================================
    getMsgP = msgEmail()
    print getMsgP‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
jaykapalczynski
Honored Contributor
I can create an array, convert to string and put that in some HTML formatting and add it to the email
But I just get a huge jumbled mess of comma delimited list/string in the email...there is no formatting...
  1. Is there a way to format the Array and add that to the email
  2. Is there a way to parse/split the string and format that?
  3. Is there a way to split the string on a specific "," (index) and then at least add a space between lines in the email?
date_list = mylist
date_list_string = "\n".join(date_list) # edit this to match the desired output
html = """<html>
<head></head>
<body>
<p>These are the available dates: </p>
""" + date_list_string + """"
</body>
</html>
part3 = MIMEText(html, 'html')
msg.attach(part3)
I GET THIS:
1,King WIlliam,Lestor Manor,2016-09-21 14:41:07,yes,na,na,na,no,Human feces all over sign,Sprayed with cleaner and washed off with bucket of water,None fruther,yes,na,na,na,yes,na,na,na,no,Erosion starting from hill,None,Will continue to monitor and follow up,no,na,Mowed grass,na,yes,na,na,na,yes,na,na,na,no,Yes,na,na,na,no,na,na,na,no,na,na,na,no,na,na,na,yes,na,na,na,yes,na,na, na,yes,na,na,na,yes,na,na,na,no,No,na,na,na,Note: Fishing line recycling tube full of trash need to monitor and remove if continues to be problem ,2016-09-21 14:44:17,jkirk922,2016-11-08 18:28:54,jay.kai,3.5861196,-7.98457474 1,King & Queen,Waterfence,2016-09-21 15:46:31,no,Missing trail blazer from tree work,Replaced,None,yes,na,na,na,yes,na,na,na,yes,na,na,na,no,Pothole forming,None,Monitor and fill with cold patch,no,na,Mowed grass,na,yes,na,na,na,yes,na,na,na,no,Yes,na,na,na,no,na,na,na,no,na,na,na,no,na,na,na,yes,na,na,na,yes,na,na, na,yes,na,na,na,yes,na,na,na,no,No,na,na,na,na,2016-09-21 15:48:08,jkirk922,2016-11-08 18:28:54,jay.kai,3.59206276,-7.79871466
AT A MINIMUM WAN THIS:
1,King WIlliam,Lestor Manor,2016-09-21 14:41:07,yes,na,na,na,no,Human feces all over sign,Sprayed with cleaner and washed off with bucket of water,None fruther,yes,na,na,na,yes,na,na,na,no,Erosion starting from hill,None,Will continue to monitor and follow up,no,na,Mowed grass,na,yes,na,na,na,yes,na,na,na,no,Yes,na,na,na,no,na,na,na,no,na,na,na,no,na,na,na,yes,na,na,na,yes,na,na, na,yes,na,na,na,yes,na,na,na,no,No,na,na,na,Note: Fishing line recycling tube full of trash need to monitor and remove if continues to be problem ,2016-09-21 14:44:17,jkirk922,2016-11-08 18:28:54,jay.kapalczynski,3.5861196,-7.98457474
jaykapalczynski
Honored Contributor
Im getting close but this results in the below....
how can I make the fields widths wider so I can read it...
with open('z_outFileRegion1.csv', 'rb') as f:
    reader = csv.reader(f)
    your_list = list(reader)
        #First, create the texts of the columns:
        cols = ["<td>{0}</td>". format( "</td><td>".join(t)  ) for t in your_list]
        #then use it to join the rows (tr)
        rows = "<tr>{0}</tr>".format( "</tr>\n<tr>".join(cols) )
        #finaly, inject it into the html...
        html1 = """<HTML> <body>
            <h1>Attendance list</h1>
                <table>
                    {0}
                </table>
            </body>
            </HTML>""".format(rows)
        part3 = MIMEText(html1, 'html')
        msg.attach(part3)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Attendance list
region
county
ramp
date
trailblazers
TrailDes
TrailActionT
railActionN
regulations
RegDes
RegActionT
regActionN
safteygsign
safteygsignP
safteygsignT
safteygsignN
rutfree
rutfreeP
rutfreeT
rutfreeN
potholes
potholesP
potholesT
potholesN
grass
grassP
grassT
grassN
trash
trashP
trashT
trashN
portapotties
portapottiesP
portapottiesT
portapottiesN
lighting
lights
lightingP
lightingT
lightingN
courtesypier
courtesypierP
courtesypierT
courtesypierN
boatslide
boatslideP
boatslideTaken
boatslideN
fishingpier
fishingpierP
fishingpierT
fishingpierN
debris
debrisP
debrisT
debrisN
potholesramp
potholesrampP
potholesrampT
potholesrampN
bulkhead
bulkheadPbulkheadTbulkheadNshorelineshorelinePshorelineTshorelineNcontractorcontractordutiescontractorPcontractorTcontractorNcommentsCreationDateCreatorEditDateEditorLatLong
King WIlliam
Lestor Manor
2016-09-21 14:41:07
yes
na
na
na
no
None fruther
yes
na
na
na
yes
na
na
na
no
None
no
na
Mowed grass
na
yes
na
na
na
yes
na
na
na
no
Yes
na
na
na
no
na
na
na
no
na
na
na
no
na
na
na
yes
na
na
na
yes
na
na
na
yes
nananayesnanananoNo nananaNote: Fishing line recycling tube full of trash need to monitor and remove if continues to be problem 2016-09-21 14:44:17jkirk9222016-11-08 18:28:54jay.ka3.5861196-7.98457474%s
BlakeTerhune
This discussion is full of poop...
Anyway, since you've ventured out of printing in Python to crafting an HTML email (which is an adventure in its self), you should start looking up ways to solve your problem with HTML. For example, the col width table attribute might be something to try for setting the width of the columns in your table. Instead, I suspect you might actually want to just set the table width to 100%.
Ultimately though, you'll be limited by the screen size of the email client rendering the html message.
JamesCrandall
Format the list items into a merged html line then populate a complete html into a message body.
mylist = [[1, "blah", "blah2", "blah3", "blah4", "blah5"], [2, "blah33", "blah44", "blah55", "blah66", "blah77"], [3, "blah111", "blah222", "blah333", "blah444", "blah555"]]
mylistitem = (["""<a href=>""" + str(i) + """</a>""" for i in mylist])
merged = [item for sublist in zip(mylistitem) for item in sublist]
htmlline = '\n'.join(merged)
#print htmlline
html = """\
        <html>
          <head></head>
          <body>
            <p><br>
                Python Script Errors & Logging Reports<br> <br> <br>
                | Log Items | <br>
                """ + htmlline + """<br> <br>
            </p>
          </body>
        </html>
print html
jaykapalczynski
Honored Contributor
When I use your code James I get this...I was looking for something that would look more formatted as line items...did I do something wrong?
        mylistitem = (["""<a href=>""" + str(i) + """</a>""" for i in your_list])
        #print htmlline
        html = """\
                <html>
                  <head></head>
                  <body>
                    <p><br>
                        | Log Items | <br>
                    </p>
                  </body>
                </html>
        print html
| Log Items |
['region', 'county', 'ramp', 'date', 'trailblazers', 'TrailDes', 'TrailActionT', 'railActionN', 'regulations', 'RegDes', 'RegActionT', 'regActionN', 'safteygsign', 'safteygsignP', 'safteygsignT', 'safteygsignN', 'rutfree', 'rutfreeP', 'rutfreeT', 'rutfreeN', 'potholes', 'potholesP', 'potholesT', 'potholesN', 'grass', 'grassP', 'grassT', 'grassN', 'trash', 'trashP', 'trashT', 'trashN', 'portapotties', 'portapottiesP', 'portapottiesT', 'portapottiesN', 'lighting', 'lights', 'lightingP', 'lightingT', 'lightingN', 'courtesypier', 'courtesypierP', 'courtesypierT', 'courtesypierN', 'boatslide', 'boatslideP', 'boatslideTaken', 'boatslideN', 'fishingpier', 'fishingpierP', 'fishingpierT', 'fishingpierN', 'debris', 'debrisP', 'debrisT', 'debrisN', 'potholesramp', 'potholesrampP', 'potholesrampT', 'potholesrampN', 'bulkhead', 'bulkheadP', 'bulkheadT', 'bulkheadN', 'shoreline', 'shorelineP', 'shorelineT', 'shorelineN', 'contractor', 'contractorduties', 'c ontractorP', 'contractorT', 'contractorN', 'comments', 'CreationDate', 'Creator', 'EditDate', 'Editor', 'Lat', 'Long'] ['1', 'King WIlliam', 'Lestor Manor', '2016-09-21 14:41:07', 'yes', 'na', 'na', 'na', 'no', 'Human feces all over sign', 'Sprayed with cleaner and washed off with bucket of water', 'None fruther', 'yes', 'na', 'na', 'na', 'yes', 'na', 'na', 'na', 'no', 'Erosion starting from hill', 'None', 'Will continue to monitor and follow up', 'no', 'na', 'Mowed grass', 'na', 'yes', 'na', 'na', 'na', 'yes', 'na', 'na', 'na', 'no', 'Yes', 'na', 'na', 'na', 'no', 'na', 'na', 'na', 'no', 'na', 'na', 'na', 'no', 'na', 'na', 'na', 'yes', 'na', 'na', 'na', 'yes', 'na', 'na', ' na', 'yes', 'na', 'na', 'na', 'yes', 'na', 'na', 'na', 'no', 'No', 'na', 'na', 'na', 'Note: Fishing line recycling tube full of trash need to monitor and remove if continues to be problem ', '2016-09-21 14:44:17', 'jkirk922', '2016-11-08 18:28:54', 'jay.ki', '37.5861196', '-76.98457474%s'] ['1', 'King & Queen', 'Waterfence', '2016-09-21 15:46:31', 'no', 'Missing trail blazer from tree work', 'Replaced', 'None', 'yes', 'na', 'na', 'na', 'yes', 'na', 'na', 'na', 'yes', 'na', 'na', 'na', 'no', 'Pothole forming', 'None', 'Monitor and fill with cold patch', 'no', 'na', 'Mowed grass', 'na', 'yes', 'na', 'na', 'na', 'yes', 'na', 'na', 'na', 'no', 'Yes', 'na', 'na', 'na', 'no', 'na', 'na', 'na', 'no', 'na', 'na', 'na', 'no', 'na', 'na', 'na', 'yes', 'na', 'na', 'na', 'yes', 'na', 'na', ' na', 'yes', 'na', 'na', 'na', 'yes', 'na', 'na', 'na', 'no', 'No', 'na', 'na', 'na', 'na', '2016-09-21 15:48:08', 'jkirk922', '2016-11-08 18:28:54', 'jay.ki', '37.59206276', '-76.79871466%s']
JamesCrandall
It's really hard to tell but I'd suspect that there is some mismatch in the number of items within the arrays in the lists.  I'd strip the down to make sure there are the same number of columns in each array.
jaykapalczynski
Honored Contributor
I tweaked this line and got the lines to separate...added 2 <br>
mylistitem = (["""<a href=>""" + str(i) + """</a><br><br>""" for i in your_list])
Questions:
  • Should I be expecting the Headers to show up before each value in each of the 2 record returns?
  • What result should I be expecting from your code?
| Log Items |
region , county , ramp , date , trailblazers , TrailDes , TrailActionT , railActionN , regulations , RegDes , RegActionT , regActionN , safteygsign , safteygsignP , safteygsignT , safteygsignN , rutfree , rutfreeP , rutfreeT , rutfreeN , potholes , potholesP , potholesT , potholesN , grass , grassP , grassT , grassN , trash , trashP , trashT , trashN , portapotties , portapottiesP , portapottiesT , portapottiesN , lighting , lights , lightingP , lightingT , lightingN , courtesypier , courtesypierP , courtesypierT , courtesypierN , boatslide , boatslideP , boatslideTaken , boatslideN , fishingpier , fishingpierP , fishingpierT , fishingpierN , debris , debrisP , debrisT , debrisN , potholesramp , potholesrampP , potholesrampT , potholesrampN , bulkhead , bulkheadP , bulkheadT , bulkheadN , shoreline , shorelineP , shorelineT , shorelineN , contractor , contractorduties , co ntractorP , contractorT , contractorN , comments , CreationDate , Creator , EditDate , Editor , Lat , Long
3 , Grayson , Independence , 2016-11-23 16:31:59 , yes , None , None , None , yes , None , None , None , yes , None , None , None , yes , None , None , None , yes , None , None , None , yes , None , None , None , yes , None , None , None , yes , None , None , None , no , None , None , None , None , no , None , None , None , no , None , None , None , no , None , None , None , yes , None , None , None , yes , None , None , None , yes , None , None , None , yes , None , None , None , no , None , None , None , None , JUNK RECORD , 2016-11-23 16:32:22 , BoatGuest , 2016-11-23 16:32:22 , BoatGuest , 36.57220761 , -81.1524287%s
3 , Grayson , Bridle Creek , 2016-11-23 16:44:01 , yes , None , None , None , yes , None , None , None , yes , None , None , None , yes , None , None , None , yes , None , None , None , yes , None , None , None , yes , None , None , None , yes , None , None , None , no , None , None , None , None , no , None , None , None , yes , fdff , fggv , g b v , no , None , None , None , yes , None , None , None , yes , None , None , None , yes , None , None , None , yes , None , None , None , no , None , None , None , None , JUNK RECORD , 2016-11-23 16:44:28 , BoatGuest , 2016-11-23 16:44:28 , BoatGuest , 36.59588241 , -81.24224305%s
JamesCrandall
import smtplib
from email.mime.multipart import MIMEMultipart
from email.mime.text import MIMEText
mylist2 = [[1, "blah", "blah2", "blah3", "blah4", "blah5"], [2, "blah33", "blah44", "blah55", "blah66", "blah77"], [3, "blah111", "blah222", "blah333", "blah444", "blah555"]]
me = "[email protected]"
you = "[email protected]"
# Create message container - the correct MIME type is multipart/alternative.
msg = MIMEMultipart('alternative')
msg['Subject'] = "Some Subject Line"
msg['From'] = me
msg['To'] = you
html = """\
<html>
  <head></head>
  <body>
    <p><br>
 | Errors Items | <br>
 | Log Items | <br>
    </p>
  </body>
</html>
part2 = MIMEText(html, 'html')
msg.attach(part2)
s = smtplib.SMTP('mail.mydomain.com', 25)
s.sendmail(me, you, msg.as_string())
print "msg sent"
s.quit()
jaykapalczynski
Honored Contributor
I used your code in a separate .py file and this is what I got....Is this what you are expecting
I needed to modify the "mylist2" variable in this line, because it just said "mylist"
mylistitem = (["""<a href=>""" + str(i) + """</a>""" for i in mylist2])
RESULTS:
| Errors Items |
| Log Items |
[1, 'blah', 'blah2', 'blah3', 'blah4', 'blah5'] [2, 'blah33', 'blah44', 'blah55', 'blah66', 'blah77'] [3, 'blah111', 'blah222', 'blah333', 'blah444', 'blah555']
