Why does WebApp Builder return with "AttributeError: DescribeData: Method FIDSet does not exist?"
995
08-10-2020 11:07 AM
NeveenD
When publishing a web tool from Pro, my tool uploads successfully. When testing the tool within WAB, I receive the following error:
fidSet = desc.FIDSet AttributeError: DescribeData: Method FIDSet does not exist
This runs perfectly fine in Pro and does not come up as an error during the publish phase. The web tool is intended to export selected images, with the portion of the script is as follows:
desc = arcpy.Describe(inView)
if fidSet:
fidList = fidSet.replace(' ','').split(';')
oidSet = set([int(oid) for oid in fidList])
else:
oidSet = set()
Any feedback would be helpful.
Thanks!
DanPatterson
fidSet = desc['FIDSet']
is arcpy's data access procedure since it returns a dictionary or 'describe' properties
... sort of retired...
DanPatterson
TableView properties—ArcGIS Pro | Documentation
Layer properties—ArcGIS Pro | Documentation
I see FIDset in both arcpy.Describe and arcpy.da.Describe but they return slightly different results
NeveenD
Thanks Dan Patterson‌,
I attempted the arcpy.da.Describe as well but attempted it a second time just in case. I receive the following error when using arcpy.da.Describe within Pro itself (meaning, as you know, that I won't be able to export the webtool)--
AttributeError: 'dict' object has no attribute 'FIDSet'
A tableview is used the script, and a join is formed between oids of a tableview of attachments and an fc.
DanPatterson
NeveenD
This worked, thank you!
