Using Python from Pro and from Desktop on the same machine
11313
11
01-14-2015 06:40 AM
ModyBuchbinder
Python
that comes with desktop is 2.7 while python that comes with pro is 3.4
They have some differences in basic syntax.
On my machine when you just run Python you gets the 3.4 version (can this be changes?).
When you try to execute desktop python programs (including ESRI tools) you get many errors.
Is there any solution to this?
Mody
JoshuaBixby
MVP Esteemed Contributor
You are only logged into AGOL when Pro is running or a script is running that uses Pro's ArcPy.  When you close out of Pro or the script terminates, you will be logged out.
If there is a security issue, or potential issue, it might be allowing Pro to automatically log you in because it means Pro is storing one's credentials.  That said, Pro encrypts the credentials it stores and there are bigger problems if your Windows or Active Directory profile has been compromised and someone else is using your profile or machine.
The only time I actively log out of AGOL from within Pro is when I am switching from AGOL to an internal portal for licensing.
