using join by in arcpy.da.searchcursor() - what is the right syntax?
3735
18
04-08-2014 06:22 AM
yonatanrubinstein
Hi, I'm trying to run a code that uses a "join by statement" inside a searchcursor (it was done to imitate the join by inside the iterate features tool in the modelbuilder). I've tried this code (as a trial before implementing it on the real script), but I can't seem to find the right syntax or any documentation.
import arcpy  fc = "D:\\Projects\\proj1\\SumsOfRoutes.gdb\\all_routes_1stBatch" field = "r_Identity" field2 = "Shape_Length" ##sql = "(None, 'GROUP BY \"r_Identity\"')" sql = "(None,'Group BY r_Identity')"   fields=["*"] cursor = arcpy.da.SearchCursor(fc,fields,sql_clause=sql)   # print r_Identity and Shape_Length of each feature in feature class for row in cursor:     print(str(int(row.getValue(field))) + ":  " + str(row.getValue(field2)) + " meters")
Does anybody know how it should be written?
EDIT: for the script above, I get the following error:
TypeError: 'sql_clause' should be sequense of 2 strings(prefix, postfix)
Thanks.
JamesCrandall
MVP Frequent Contributor
Update:
This must be a bug or something because I don't see how this can be correct.  According to Shaun's reply in this thread: http://forums.arcgis.com/threads/77876-Group-By-functionality-of-da.cursors-sql_clause the suggestion is to include the "ObjectID" field in the group by clause to overcome the error you are experiencing.  Here's my working code:
 fc = r'H:\Documents\ArcGIS\Default.gdb\RainGauges' fields = ('Data_Type')  sql=[None, "GROUP BY Data_Type, ObjectID"] cursor = arcpy.da.SearchCursor(fc, fields,sql_clause=sql)  for row in cursor:     print row[0]
HOWEVER, this completely defeats the ability to actually group rows because the ObjectID is a unique value!!  lol...  Maybe I am simply misunderstanding here, but that is exactly what is happening in my test data.  That is, it doesn't matter if real/actual groups exist in my select fields, they will NEVER group correctly because I must include the ObjectID in the group by clause (it is unique values).
I am happy to be corrected on this one!
JoshuaChisholm
Hello Yonatan,
I think sql_clause needs to be passed as a tuple. Try removing the quotes:
sql = (None,'GROUP BY r_Identity')
On a side note, you could probably increase the efficiency of your script by only pulling the fields you need for the da.SearchCursor. Like this:
fields=[field,field2]
Let me know how it goes!
JamesCrandall
Here's my guess...
Change:
To:
sql = [None,"GROUP BY r_Identity"]
yonatanrubinstein
Hi Joshua,
Thanks for the quick response.
1. As far as I Know, the sql_clause is a string. As evidence, when I do as you suggested and write
TypeError: 'where_clause' is not a string
, so that is why I have the quotation marks. Any Ideas?
2. I know listing only 2 fields will  increase the efficiency of the cursor, but will it enable me to use other field in the layer, later on?
JamesCrandall
I just noticed you have this:
fields=["*"]
This is not allowable in a GROUP BY statement.  That is, you could not write it as:
SELECT *
FROM table1
GROUP BY table1.field1
You must specify the fields you wish to include in the group by too!!!  Like this:
SELECT table1.field1, table1.field2
FROM table1
GROUP BY table1.field1, table1.field2
JamesCrandall
Update:
yonatanrubinstein
OK, James,
I tried to rewrite the script by your 2 suggestions:
import arcpy
field1 = "r_Identity"
sql = [None,'Group BY r_Identity']
fields=[field1,field2]
for row in cursor:
    print str(row)
RuntimeError: An invalid SQL stament was used. [SELECT r_Identity, Shape_Length, OBJECTID FROM all_routes_1stBatch GROUP BY r_Identity]
Any Ideas as to what's wrong?
and the question I asked Joshua:  I know listing only 2 fields will increase the efficiency of the cursor, but will it enable me to use other fields in the layer later on?
JamesCrandall
OK, James,
import arcpy
for row in cursor:
    print str(row)
You cannot include Shape_Length (see bold above) in your select because it is not included in your GROUP BY portion.  Remove it and see if it at least completes without error.
yonatanrubinstein
Update:
for row in cursor:
    print row[0]
I get the same runtimeerror as before... 😞
JamesCrandall
Is "r_Identity" the actual field name?
Make sure the spellng is correct. I get the same error in my working example if it is incorrectly spelled.
