Select by Attribute
404
06-16-2014 08:12 AM
SaidDouai
This is my first time to try Python script. I want to select a many states with a thousand records if i have to do this manually through Arc Map it will take a long time. Can anyone help me with a simple example of python script on how to run this function.
Thanks everyone.
Said
markdenil
Occasional Contributor III
Look at the Select Layer By Attribute (Data Management) tool help.....
pay attention to the part about the where_clause
AdamCox1
Just to point out, if you only need to do this a couple of times you could just use the Select by Attribute tool from the Selection menu.
