Scripts works in ArcMap Python's window, but failed in the command prompt?
654
07-12-2018 04:33 AM
KeenanGebze1
I have an ArcMap user that uses the script below.
The script works in ArcMap interactive python window but does not works in stand alone script mode (cmd).
It throws a RuntimeError while accessing a FeatureClass in SQL Server geodatabase.
import arcpy
import datetime
from datetime import date, timedelta, datetime
import time
#fcView = u"D:\\apps\\DailyProgress\\sa@gkmgsa3.sde\\SMFFMIS.dbo.vw_OutstandingWO"
fcWO = u"D:\\apps\\DailyProgress\\sde@gkmgsa3.sde\\POLYPIP_OPT.sde.GeoOutstandingWO"
fields = ["ID","SpkNumber","SpkItemNo","Contractor","KeyID","Rotation","ProjectNetwork","OperationActivity","Remark","SpkStartDate","SpkFinishDate","Qty","ActualWork","Nama_Pengawas","PERNR","PlantCode","DistrictCode","CompanyCode","CRT_Date","MOD_Date","MOD_UserID","isDone","SHAPE"]
rowsInsert = arcpy.da.SearchCursor(fcWO, fields) # error producing code
for row in rowsInsert:
  print(row)
del rowsInsert
What is not working in the stand alone script
Accessing cursors return a RuntimeError.
arcpy.Describe raises an IOError
arcpy.GetCount_management and few others GP Tools raises an arcgisscripting.ExecuteError.
What is working in the stand alone script
arcpy.ListFeatureClasses successfully returned the feature classes in the geodatabase.
The environment
Operating System
Windows server 2008 R2 64 bit
ArcMap
10.4.1
Python
C:\Python27\ArcGIS10.4
Database
SQL Server 2012
The geodatabase created using ArcGIS 10.4.1's Python
What we did
1. Reinstall the ArcMap. Result: not working.
2. Suspected the environment variables. Tried to copy the sys.path of the desktop to the stand alone script. Result: not working.
3. By chances, we found the solution is to run the arcpy.GetCount_management twice (after the first one raises an error).
4. We're doing step (3) as a work around and still trying to reproduce the error.
My suspicion
It seems that there is an additional steps used by ArcMap to connect to the database, which is not present in the stand alone (cmd) mode.
What I want to ask
1. How to resolve the problems, what is happening there?
Images
Figure 1 Displaying the first entry of the row in ArcMap’s Python window.
Figure 2 RuntimeError when executed as stand alone script via command prompt.
Figure 3 IOError when using arcpy.Describe()
Figure 4 Using arcpy.GetCount_management() raise an arcgisscripting.Exception, but works if repeated after the exception.
Figure 5 After exception was raised in figure 4, all of the subsequent code was working!
Workspace properties
connectionProperties.authentication_mode
DBMS
Database
POLYPIP_OPT
historical_timestampe
Exception
connectionProperties.isGeodatabase
True
connectionProperties.instance
sde:sqlserver:gkmgsa3
connectionProperties.server
gkmgsa3
connectionProperties.user
sde
connectionProperties.version
sde.Default
connectionProperties.connectionString
currentRelease
True
Domains
Release
3,0,0
workspaceFactoryProgID
esriDataSourcesGDB.SdeWorkspaceFactory.1
workspaceType
RemoteDatabase
Thankyou for your attention..
Regards,
DanPatterson_Retired
have you got a python IDE associated with ArcMap?  It is almost like you have a disconnect with python.
KeenanGebze1
Hi Dan,
What do you mean by associated with ArcMap? Is it when the IDE default path is in the C:\\Python27\ArcGIS10.4\... ?
I think the user has IDLE Python.
But the script itself is executed on the command prompt..
