RuntimeError: Object: CreateObject cannot create geometry from inputs
4944
10-31-2017 08:11 AM
DevonCanady
I cannot seem to create a geometry using a list of coordinates. I'm parsing these coordinates from a JSON object, which I have successfully tested, but from the documentation it seems this should work once I have a double to input. Here is another similar example.
import arcpy, json
jsonObj = """{
"points": [
      "Y": 35.631453769591765,
      "X": -97.586939334869385
      "Y": 35.628907432142576,
      "X": -97.587132453918457
      "Y": 35.627703997864323,
      "X": -97.589900493621826
      "Y": 35.630180611005642,
      "X": -97.590758800506592
      "Y": 35.630302695584653,
      "X": -97.5909948348999
  "spatialReference": {
    "wkid": 4326
dictionary = json.loads(jsonObj)
#the Polygon method fails whether I input a list of Points or PointGeometries
coordsList = []
for items in dictionary["points"]:
    pt = arcpy.Point(items["X"], items["Y"])
    coordsList.append(arcpy.PointGeometry(pt, arcpy.SpatialReference(4326)))
geometry = arcpy.Polygon(coordsList, arcpy.SpatialReference(4326)) #fails here
# arcpy.CopyFeatures_management(geometry, FILEPATH)
JoshuaBixby
MVP Esteemed Contributor
You are close, try this:
import arcpy, json
jsonObj = """{
"points": [
    "wkid": 4326
coordsList = arcpy.Array()
    coordsList.append(pt)
JoshuaBixby
import arcpy, json
jsonObj = """{
"points": [
    "wkid": 4326
DevonCanady
Yep! Thanks
