I have been running my python script that uses arcpy, from Powershell without any problems. But in the middle of a session, I thought to update ArcGIS Pro from 3.0.1 to 3.1 and my script immediately stopped working. I run my script from Powershell using propy (the propy.bat file location is added to my environmental variables). The following error is produced:
Unhandled exception. System.IO.FileNotFoundException: Could not load file or assembly 'ArcGIS.Core, Version=13.1.0.0, Culture=neutral, PublicKeyToken=8fc3cc631e44ad86'. The system cannot find the file specified.
File name: 'ArcGIS.Core, Version=13.1.0.0, Culture=neutral, PublicKeyToken=8fc3cc631e44ad86'
at ArcGIS.Core.Internal.PluginWorkspaceFactoryShim.FinalConstruct(PluginWorkspaceFactoryShim* )
at ATL.CComPolyObject<ArcGIS::Core::Internal::PluginWorkspaceFactoryShim>.FinalConstruct(CComPolyObject<ArcGIS::Core::Internal::PluginWorkspaceFactoryShim>* )
at ATL.CComPolyObject<ArcGIS::Core::Internal::PluginWorkspaceFactoryShim>.CreateInstance(IUnknown* pUnkOuter, CComPolyObject<ArcGIS::Core::Internal::PluginWorkspaceFactoryShim>** pp)
at ArcGIS.Core.Internal.PluginWorkspaceFactoryShim.CreateInstance(IAddInRecord* pAddinRecord, IUnknown* controllingUnknown, IUnknown** ppPluginWorkspaceFactory)
at PluginFactory.CreateObject(PluginFactory* , IAddInRecord* pAddinRecord, IUnknown* pUnkOuter, IUnknown** ppPluginWorkspaceFactory)
This only happens when a method that takes a file name or location as a parameter is run. For instance, the following doesn't produce an error:
arcpy.env.overwriteOutput = True // no error
But this does:
arcpy.env.workspace = "location of gdb" //error
and so does this:
arcpy.Exists("location of gdb that exists") //error
but the following doesn't produce an error; just prints False.
arcpy.Exists("") //no error
I've tried restarting my Windows and rechecking environmental variables in Systems Settings. The same commands run fine from within ArcGIS Pro's python window. As far as I could tell, this started happening after I upgraded to Pro 3.1
Anyone have any idea what could be wrong here? I need to use propy or python to run my script from the shell.
Both python or propy commands from shell give same error
