run RebuildAddressLocator from python (arcgis pro) but get Error 000005: Could not open the address locator
2424
11
10-17-2024 11:15 PM
geopamplona
Hi
I try to run RebuildAddressLocator from python and I get the same error ‘Error 000005: Could not open the address locator’.
I have tried to create the locator from arcgis pro 2.9.5, I generate the loc and loz files, and I try to rebuild the locator, everything works correctly using arcgis pro; but if I close arcgis pro and open it again I can't rebuild the locator and I get Error 000005: Could not open the address locator
The locator source is a feature layer hosted in an enterprise sqlserver database with no locks, as it is a layer that is not published as a service, and with versioning.
I work under a version arcgis pro 2.9.5 and always logged against portal 10.9.1.
I have installed the license manager on the machine I run from but I haven't changed anything.
The idea would be to go ahead and launch this from python as you do to schedule it weekly but I can't get out of this simple point.
Thank you!
DanPatterson
MVP Esteemed Contributor
You indicate you are using python, so presumably your script may be at issue.  In any event have you examined all the possible reasons that this error may be shown and their solutions as listed in the help files.
000005: Could not open the address locator.—ArcGIS Pro | Documentation
... sort of retired...
geopamplona
The script is simply trying to rebuild the locator.
The problem is that both in the script and in ArcGIS Pro I get the same error, it fails to access the data source.
arcpy.geocoding.RebuildAddressLocator(r"C:\test\locator.loc")
DanPatterson
The only other reference, which mentions python scripts, appears here
FAQ: Best Practices for Deploying Address Locators on a Network Location to Avoid Locking (esri.com)
MichaelVolz
Is the locator itself being used in a geocode service?  If so, you need to stop the geocode service.
You said "The locator source is a feature layer hosted in an enterprise sqlserver database."  Does this mean this is a standard enterprise feature class or is this a service?
Was your connection to the enterprise SQL Server database done using a location sde connection on the C-drive or was it a mapped network drive location to the sde connection?
MarkGambordella
Did you ever find the reason why and if so what is the workaround.  having same issue, will not rebuild in Arc Pro or script (Error 000005) .  We switched from an Oracle to SQL server and built the NEW locators exactly the same, then the issue began.  they path directly to the NEW SQL SDE database.  I am signed in with my Microsoft authenticator (all restrictions).  I am able to build them but not rebuild.  I can use them in AGO and PRO.  The composite is published to the REST server as a geolocator in AGO which in turn is used in everyone's PRO for the organization.
MarkGambordella
Did you ever find the reason why and if so what is the workaround.  having same issue, will not rebuild in Arc Pro or script.  We switched from an Oracle to SQL server and built the NEW locators exactly the same, then the issue began.
mthompson
I am also unable to rebuild any address locator I create. I created a brand new locator pointing at a point layer in our SQL Enterprise GDB which built successfully and works great. I try to rebuild it, and I get "Error 999999 Something unexpected caused the tool to fail" and "Error 000005 Could not open the address locator". None of the steps in this article help. https://pro.arcgis.com/en/pro-app/3.4/tool-reference/tool-errors-and-warnings/001001-010000/tool-err...
MikeVolz
What version of ArcGIS Pro are you building the address locator in?
mthompson
We are using 3.5.6
