I have a toolbar which enables a second and third combobox when a selection is made on the previous. I would like to add a button to 'reset' the toolbar. Basically clear the selection and return toolbar to the state it was when originally loaded? Any thoughts? Here is what I have...
import arcpy
import pythonaddins
layer = arcpy.mapping.ListLayers(arcpy.mapping.MapDocument("CURRENT"))[0]
arcpy.SelectLayerByAttribute_management(layer,"CLEAR_SELECTION")
arcpy.RefreshActiveView()
class Survey(object):
"""Implementation for DatabaseSearch_addin.combobox1 (ComboBox)"""
def __init__(self):
#in the initialisation of the addin
self.items = []
self.editable = True
self.enabled = True
self.dropdownWidth = 'WWWWWW'
self.width = 'WWWWWW'
#set the map document reference
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd)[0]
layer = arcpy.mapping.ListLayers(mxd)[0]
# check if the layer exists
if layer:
#create a column name variable for the search cursor parameters
column_BlockNo = "L1SURNAM"
sc = arcpy.SearchCursor(layer,""""L1SURNAM" <> ' '""","",column_BlockNo,column_BlockNo)
#Due to the multiple values stored in the attribute table a dictionary had to be used
#Create a dictionary
dictionary = {}
#for loop to iterate through the attribute tables getting the values for the column
for row in sc:
#set the value as the row value in the column block number
val = row.getValue(column_BlockNo)
#the nature of dictionaries does not allow for duplicates thus handling the redundant block numbers in the data table for use in the combobox
dictionary[val] = val
#create a list of items for the dictionary's unique keys to be written to
Items = []
#for loop to iterate through the keys in the dictionary
for key in dictionary.iterkeys():
#append the key values to the list Items
Items.append(key)
#append the list of keys to the Blocknumber(self) item list
self.items.append(key)
#sort keys in ascending numeric order
self.items.sort()
del row
del sc
def onSelChange(self, selection):
arcpy.SelectLayerByAttribute_management(layer,"NEW_SELECTION","L1SURNAM = '" + selection + "'")
df.zoomToSelectedFeatures()
#if the layer exists
dictionary = {}
if layer:
#empty the lot number item list
combobox2.items = []
#create a variable for the lot number
column_Lot = "L2BLOCK"
#create a search cursor for the layer on the lot number field selecting all the values that are not an empty string
sc = arcpy.SearchCursor(layer,""""L2BLOCK" <> ' '""","",column_Lot,column_Lot)
#for loop to read through the values in the lot number field
for row in sc:
val = row.getValue(column_Lot)
combobox2.items.append(key)
combobox2.items.sort()
combobox2.enabled = True
del row
del sc
def onEditChange(self, text):
#create a variable to store the text in for the selection tool
SurNam = text
arcpy.SelectLayerByAttribute_management(layer,"NEW_SELECTION","L1SURNAM = '" + SurNam + "'")
class Block(object):
"""Implementation for DatabaseSearch_addin.combobox2 (ComboBox)"""
def __init__(self):
self.items = []
self.enabled = False
arcpy.SelectLayerByAttribute_management(layer,"SUBSET_SELECTION","L2BLOCK = '" + selection + "'")
dictionary = {}
if layer:
combobox3.items = []
column_Sur = "L3SURNUM"
sc = arcpy.SearchCursor(layer,""""L3SURNUM" <> ' '""","",column_Sur,column_Sur)
for row in sc:
val = row.getValue(column_Sur)
combobox3.items.append(key)
combobox3.items.sort()
combobox3.enabled = True
del row
del sc
blockNum = text
arcpy.SelectLayerByAttribute_management(layer,"SUBSET_SELECTION","L2BLOCK = '" + blockNum + "'")
class Section(object):
"""Implementation for DatabaseSearch_addin.combobox3 (ComboBox)"""
def __init__(self):
self.items = []
#only activated when survey name is populated
arcpy.SelectLayerByAttribute_management(layer,"SUBSET_SELECTION","L3SURNUM = '" + selection + "'")
class Rest(object):
"""Implementation for DatabaseSearch_addin.button3 (Button)"""
def __init__(self):
self.enabled = True
self.checked = False
def onClick(self):
combobox2.items()
combobox2.enabled = False
combobox3.items()
combobox3.enabled = False
