Remove all numbers/integer values from multiple fields
656
7
08-22-2019 03:33 PM
CCWeedcontrol
Occasional Contributor III
I have some fields with alphabetic and numbers i want to remove all the numbers. I have tried some things but the issue i have is that the numbers are between the alphabetic text for example
Homeowners field
"Homeowners 456 Exempt",---> Homeowners Exempt
"456 Homeowners Exempt"--> Homeowners Exempt
"Homeowners Exempt 456" --> Homeowners Exempt
Irrigation
Hill Irrigation #2 Dist --> Hill Irrigation Dist
#2Hill Irrigation Dist --> Hill Irrigation Dist
Hill Irrigation Dist#2 --> Hill Irrigation Dist
Drain
High Drain #2 Dist --> High Drain Dist
#2High Drain Dist --> High Drain Dist
High Drain Dist #2--> High Drain Dist
I have tried .strip('0123456789. -#') but it only removes them from the beginning and end not in between.
Ive been working with this but i can't seem to get right. I would appreciate any help.
fc = r"C:\Temp\Lyr1"
fields = ['HomeOwners', 'Irrigation', 'Drain']
exp = ''.join(c for c in fields if not c.isnumeric())
arcpy.management.CalculateField(fc, fields, exp, "PYTHON3")
 get the following error
RuntimeError: Object: Error in executing tool
DanPatterson_Retired
# --- the key is the list of the string
# dump = list('0123456789#')
# dump
# ['0', '1', '2', '3', '4', '5', '6', '7', '8', '9', '#']
# --- now make the function
def dump_stuff(fld):
    """add to dump if needed"""
    return "".join([i for i in fld if i not in dump])
# ---- now test it
a = "some #1 test in 234 field"
dump_stuff(a)
'some  test in  field'
# dump
# ---- now test it
dump_stuff(a)
CCWeedcontrol
I was always told to avoid functions when using field calculator and therefor never done it. So i am not sure how to use the function with field calculator.
It need not be a field calculator expression.  You can call that def within a loop that collects all your text fields in a featureclass.  Pass the field's name to the function and it work  with an updatecursor or the field calculator call as Joshua indicated.  The key is the function.
CCWeedcontrol
I was able to get to work with arcpy.da.UpdateCurosr.
with arcpy.da.UpdateCursor(fc, fld) as cursor:
    for row in cursor:
        s = row[0]
        row[0] = dump_stuff(row[0])
        row[1] = dump_stuff(row[1])
        row[2] = dump_stuff(row[2])
        cursor.updateRow(row)
del cursor
JoshuaBixby
MVP Esteemed Contributor
Speaking just to the code snippet you provided, the Field Calculator acts on one field at a time, you can't pass it a list of fields to operate on independently.  If you want to process multiple fields using the same method/approach, you will need to loop over a list of fields and call Field Calculate on each one.
for fld in fields:
    exp = # some expression that is formatted correctly
    arcpy.management.CalculateField(fc, fld, exp, "PYTHON3")
CCWeedcontrol
Based on what you stated that you can't pass a list of fields. Here is what i came up with, correct?
This took about 2.06 mins where using arcpy.da.UpdateCursor only took 4 seconds. The only issue with the code below is that it removed everything that was not alphabet character but it didn't leave a space, like so. I need there to be a space.
Drain
High Drain #2 Dist --> HighDrainDist
#2High Drain Dist --> HighDrainDist
High Drain Dist #2--> HighDrainDist
code I used.
for fld in fields:
    exp = "''.join([i for i in !HomeOwners! if i.isalpha()])"
    arcpy.management.CalculateField(fc, 'HomeOwners', exp, "PYTHON3")
    exp = "''.join([i for i in !Irrigation! if i.isalpha()])"
    arcpy.management.CalculateField(fc, 'Irrigation', exp, "PYTHON3")
    exp = "''.join([i for i in !Drain! if i.isalpha()])"
    arcpy.management.CalculateField(fc, 'Drain', exp, "PYTHON3")
JoshuaBixby
Try:
"''.join([i for i in !Irrigation! if any((i.isalpha(), i.isspace()))]).strip()"
(and, by the way, I think you have already shown using a cursor is much more efficient)
