Reclassify failure: cannot set input into parameter remap
2337
9
10-22-2020 02:57 PM
IanDavies
New Contributor III
I am reclassifying texture classes of a soil raster into integers:
import arcpy
from arcpy import env
arcpy.CheckOutExtension('Spatial')
soil_path = 'C:\\Users\\....\\soil.gdb\\soil_raster"
class_map = [('Loamy very fine sand', 1), ('Sandy loam', 2), ('Loamy fine sand', 1), ('Silt', 4), ('Sandy clay', 11), ('Fine sand', 3), ('Very fine sandy loam', 2), ('Coarse sand', 3), ('Loamy sand', 1), ('Clay', 7), ('Very fine sand', 3), ('Silty clay', 9), ('Coarse sandy loam', 2), ('Loamy coarse sand', 1), ('Sand', 3), ('Sandy clay loam', 5), ('Clay loam', 6), ('Silty clay loam', 10), ('Silt loam', 4), ('Loam', 8), ('Fine sandy loam', 2)]
remap_values = arcpy.sa.RemapValue(class_values)
soil_reclass = arcpy.sa.Reclassify(in_raster='soil_path', reclass_field='texcl', remap=remap_values)
This returns an error
ExecuteError: ERROR 000622: Failed to execute (Reclassify). Parameters are not valid.
ERROR 000628: Cannot set input into parameter remap.
I am able to run the Reclassify tool just fine in ArcMap with these values, but copying the code as Python snippet doesn't help because once I format it for a standalone script, the error returns. (One weird thing: when pasting the snippet, some of the strings were unquoted, like clay instead of 'clay'.)
There was a similar question on here for which the answer was to check for repeat keys in the remap, but there aren't any here. Any ideas? Banging my head against my desk on this one.
DanPatterson
MVP Esteemed Contributor
strange... the help and their examples show a list of lists
... is a list of lists, with the inner lists being composed of two components....
and you have a list of tuples... hopefully they are just looking for a list of iterable containers and aren't that fussy...
worth a look though
... sort of retired...
IanDavies
New Contributor III
Hey Dan - good eye. Unfortunately that still doesn't work. Must be something wrong with my raster file ...
DanPatterson
figured it out
class_map
 ('Sandy loam', 2),
 ('Silt', 4),
 ('Sandy clay', 11),
 ('Fine sand', 3),
 ('Coarse sand', 3),
 ('Loamy sand', 1),
 ('Clay', 7),
 ('Silty clay', 9),
 ('Sand', 3),
 ('Clay loam', 6),
 ('Silt loam', 4),
 ('Loam', 8),
  File "<ipython-input-15-28e6a22766e3>", line 1, in <module>
NameError: name 'class_values' is not defined
You put class_values into sa.RemapValue instead of class_map
with the fix
 dir(remap_values)
['_CompoundParameter__propertyGetter', '_CompoundParameter__propertySetter',
 '___keyword', '__class__', '__delattr__', '__dict__', '__dir__', '__doc__', '__eq__',
 '__esri_toolinfo__', '__format__', '__ge__', '__getattribute__', '__gt__', '__hash__',
 '__init__', '__init_subclass__', '__le__', '__lt__', '__module__', '__ne__', '__new__',
 '__reduce__', '__reduce_ex__', '__remapTable', '__repr__', '__setattr__', '__sizeof__',
 '__str__', '__subclasshook__', '__weakref__', '_addProperty', '_keyword',
 '_toRepresentation', '_toString', '_useDefault', 'remapTable']‍‍
IanDavies
New Contributor III
Oh haha, my "minimal example" seems to be poorly written....
Thank you for catching that. I rewrote it as you suggested and now the remap_values looks like this:
remap_values
RemapValue([['Loamy very fine sand', 1], ['Sandy loam', 2], ['Loamy fine sand', 1], ['Silt', 4], ['Sandy clay', 11], ['Fine sand', 3], ['Very fine sandy loam', 2], ['Coarse sand', 3], ['Loamy sand', 1], ['Clay', 7], ['Very fine sand', 3], ['Silty clay', 9], ['Coarse sandy loam', 2], ['Loamy coarse sand', 1], ['Sand', 3], ['Sandy clay loam', 5], ['Clay loam', 6], ['Silty clay loam', 10], ['Silt loam', 4], ['Loam', 8], ['Fine sandy loam', 2]])
dir(remap_values)
['_CompoundParameter__propertyGetter', '_CompoundParameter__propertySetter', '___keyword', '__class__', '__delattr__', '__dict__', '__doc__', '__eq__', '__esri_toolinfo__', '__format__', '__getattribute__', '__hash__', '__init__', '__module__', '__new__', '__reduce__', '__reduce_ex__', '__remapTable', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', '__weakref__', '_addProperty', '_keyword', '_toRepresentation', '_toString', '_useDefault', 'remapTable']
So everything looks great, unfortunately it is still returning the same error for me.
DanPatterson
Check to see if you have all the classes (ie nodata) and check your raster
IanDavies
New Contributor III
Hmm no that doesn't seem to help! Thanks for helping though. I figured out a way to make this work which is from from elegant. But basically I am just re-using the "copy snippet as python" bit from running reclassify in ArcMap.
arcpy.gp.Reclassify_sa("C:/Users/.../soil.gdb/soil_raster", "texcl", "'Silt loam' 4;'Sandy loam' 2;'Fine sandy loam' 2;Loam 8;'Coarse sandy loam' 2;'Loamy sand' 1;Sand 3;'Loamy fine sand' 1;'Sandy clay loam' 5;'Very fine sandy loam' 2;'Coarse sand' 3;'Clay loam' 6;'Loamy coarse sand' 1;'Fine sand' 3;'Silty clay loam' 10;'Silty clay' 9;Clay 7;'Very fine sand' 3;Silt 4;'Loamy very fine sand' 1", soil_reclass, "DATA")
You'll see it's weird because "clay" and "sand" don't have quotation marks around them, which seems random, so I can't dynamically generate these remap values should I need to change the classes. But I can run this in Python.
DanPatterson
That sounds like a bug... I would report it, there shouldn't be a reason to have random omissions of text bits
There are bugs though
BUG-000121215: Remap Function remaps incorrect values in ArcGIS Des..
BUG-000086955: Changes to the range values in the remap table of th..
DuncanKinnear
New Contributor III
Hi Ian,
Having exactly the same issue, and stumbled across this thread which helped me understand where the error was coming from. For some reason, The Reclassify tool needs any text field value with a space to have quotation marks around it. So in my case needs this:
remap = RemapValue([["'Bare Ground'", 100], ["Grass", 0], ["Litter", 0], ["Shadow", 0], ["Shrub", 0], ["Water", 100], ["NODATA", 0]])
Also worth noting, when I pull out the class names from the input classified raster, they come across with these quotation marks too:
'Bare Ground';Water (example of input classes read from the classified raster)
But as I was creating the list dynamically based on chosen input parameters on a custom script, the 'double quotations' weren't coming across to the table I feed into the RemapValue tool and Reclassify wouldn't run.
Anyway, my solution (which I haven't actually coded yet!) is to find the classes that contain spaces and add those double quotations. Will come back one I've done that..
Cheers
Duncan
allison_wadnr
Thanks @DuncanKinnear !    This was obscure and exactly what I needed to resolve that same issue.
