Python Toolbox Derived Output Issues
12015
12
01-10-2016 06:07 PM
by Anonymous User
Not applicable
I am creating a python toolbox in ArcGIS 10.1 and have a python script working as a stand-along script but when I try to bring it into a python toolbox the tool does OK at creating an output XYZ event theme layer with the arcpy.MakeXYEventLayer_management tool and then I do create an output fc using arcpy.FeatureClassToFeatureClass_conversion which does create the fc on disk but when I try to use this fc as input in the next process to create a new fc that uses filter (sql_where_clause) the tool can not recognize the input fc that was just created on disk.  I am new at python toolboxes and think it is likely that I am not using the tools parameters properly. After having read all of the forums etc. that I could find I still am no closer to figuring this out. When I hard code the fc paths and use those as inputs into the next tool I use in the process the code can complete OK albeit not getting it using dynamic parameters.  The majority of the code I am using is below. Any suggestions about how to use the python toolbox parameters correctly?
class Toolbox(object):
    def __init__(self):
        """Define the toolbox (the name of the toolbox is the name of the
        .pyt file)."""
        self.label = "Toolbox"
        self.alias = ""
        # List of tool classes associated with this toolbox
        self.tools = [Tool_Test]
class Tool_Test(object):
    def __init__(self):
        """Define the tool (tool name is the name of the class)."""
        self.label = "Tool"
        self.description = ""
        self.canRunInBackground = False
    def getParameterInfo(self):
        """Define parameter definitions"""
        params = None
        """Define well location input csv file parameter definitions"""
        # First parameter
        param0 = arcpy.Parameter(
            displayName="Input File",
            name="in_file",
            datatype="DEFile",
            parameterType="Required",
            direction="Input")
        # To define a file filter that includes .csv and .txt extensions,
        #  set the filter list to a list of file extension names
        param0.filter.list = ['txt', 'csv']
        # Second parameter
        """Define derived well track fc parameter definitions"""
        param1 = arcpy.Parameter(
            displayName="Output Well Track Features",
            name="out_fc_well_track",
##            datatype="GPFeatureLayer",
            datatype="DEFeatureClass",
            parameterType="Derived",
            direction="Output")
##        param1.parameterDependencies = [param0.name]
        # Third parameter
        """Define derived well fc parameter definitions"""
        param2 = arcpy.Parameter(
            displayName="Output Well Features",
            name="out_fc",
            direction="Output")
##        param2.parameterDependencies = [param0.name]
        #add each param to list
##        params = [param0, param1]
        params = [param0, param1, param2]
        return params
    def isLicensed(self):
        """Set whether tool is licensed to execute."""
        return True
    def updateParameters(self, parameters):
        """Modify the values and properties of parameters before internal
        validation is performed.  This method is called whenever a parameter
        has been changed."""
        return
    def updateMessages(self, parameters):
        """Modify the messages created by internal validation for each tool
        parameter.  This method is called after internal validation."""
        return
    def execute(self, parameters, messages):
        """The source code of the tool."""
        # set local variables
        XY_Layer = 'in_file'
        out_fc_well_track = 'out_fc_well_track'
        out_fc = 'out_fc'
        # get input_fc name
        if parameters[0] != None:
            inCSV_file = parameters[0].valueAsText
            in_file_name = os.path.splitext(os.path.basename(inCSV_file))[0]
            arcpy.AddMessage("in_file_name: " + in_file_name)
            # Validate the output name so it is valid
            well_fc_name = arcpy.ValidateTableName(in_file_name)
            arcpy.AddMessage("input name validated: " + well_fc_name)
            out_fc_well_track = well_fc_name + "_well_track"
            if arcpy.Exists(out_fc_well_track):
                arcpy.Delete_management(out_fc_well_track)
            if arcpy.Exists(well_fc_name):
                arcpy.Delete_management(well_fc_name)
            arcpy.AddMessage("Start XYZ Tool...")
            # Make the XY event layer...
        ##    arcpy.MakeXYEventLayer_management(inCSV_file, x_coords, y_coords, XY_Layer, sr_In, z_coords)
            arcpy.MakeXYEventLayer_management(inCSV_file, "X_usft", "Y_usft", XY_Layer, sr_In, "TVD_usft")
            # create well track fc
##            arcpy.SetParameter(1,out_fc_well_track)
            arcpy.AddMessage("Start FC to FC Tool...")
            arcpy.FeatureClassToFeatureClass_conversion(XY_Layer, out_wrk_spc, out_fc_well_track)
            arcpy.AddMessage("Completed FC to FC Tool..." + out_fc_well_track)
            # create well fc
            out_fc = well_fc_name
            arcpy.SetParameter(2,out_fc)
            delimitedField = arcpy.AddFieldDelimiters(out_wrk_spc, where_field)
            sql_where = delimitedField + " IN('SHL', 'TPH', 'BHL')"
            arcpy.AddMessage("sql_where clause: " + sql_where)
            # using sql query to filter out SHL, TPH, and BHL from well track fc
            # TODO: remove hard code and use paramaters as intended...
##            out_fc_well_track = r'O:\Alaska\GIS\cook_inlet\maps\MRA\Code\TRS_Distances\data\MTRS_wells.gdb\SCU_322C_04_WP04___GIS_Format_well_track'
            arcpy.FeatureClassToFeatureClass_conversion(out_fc_well_track, out_wrk_spc, out_fc, sql_where)
##            arcpy.SetParameter(2,out_fc)
            arcpy.AddMessage("Completed FC to FC Tool..." + out_fc)
##            out_fc = r'O:\Alaska\GIS\cook_inlet\maps\MRA\Code\TRS_Distances\data\MTRS_wells.gdb\SCU_322C_04_WP04___GIS_Format'
            # Print the total rows
            if int(arcpy.GetCount_management(out_fc)[0]) == 0:
                arcpy.AddError("{0} has no features.".format(out_fc))
                arcpy.AddMessage('ERROR occurred because SHL, TPH, or BHL were not found in input file' )
                arcpy.AddMessage('Unable to continue! Please correct ERROR!' )
                raise arcpy.ExecuteError
            else:
                arcpy.AddMessage(out_fc + " has feature count of: " +  str(arcpy.GetCount_management(out_fc)))
             # add Well_Desc column
            arcpy.AddMessage("Adding 'Well_FC' field to well fc...")
            arcpy.AddField_management(out_fc, field_name, "TEXT", field_length=50)
            # update the new Well_Desc field
#            updateWell_Desc(out_fc)
            arcpy.AddMessage("Updated Well_Desc column!")
        return
by Anonymous User
Not applicable
Thanks Rebbecca,  I pretty much muddle through until I hit upon the right syntax and parameters.What I posted
was actually only the execute def from a much larger script. It all works at an acceptable level now. Most of the code I wrote is proprietary to one degree or another so I didn't want to post everything.
I see you are in AK too.  If you want to see the full script I could email it to you if you want to share your email address if that is kosher.
RebeccaStrauch__GISP
Yep, in Anch.  Check out the Alaska GIS Users if you haven't already.  Not real active yet, but it can be a complimentary site to the Alaska Arc User group  and other local user groups.
Btw, I can see using a python toolbox if the items are proprietary. Not much of my development is, and I try not to over complicate things if I can help it.  I'll follow you here on geonet, that will allow you to direct message me. I can send you me email that way.
Michael,
You can easily share python addins with others (again, not ArcGIS Pro or per-10.1 I think). Besides all the links Dan provided..if you
1) use Creating a toolbox—Help | ArcGIS for Desktop   to create you own toolbox in a location of your choice
2) use Adding tools to a toolbox—Help | ArcGIS for Desktop
   and Adding a script tool—Help | ArcGIS for Desktop
   and Setting script tool parameters—Help | ArcGIS for Desktop
   to add your standalone script to you new toolbox...setting up you parameters there,
3) once you get you toolbox the way you want, look over my tips Tip: Python Addin - getting custom tools/toolbox to work - GPToolDialog
Setting up parameters thru the script dialog is easier (in my opinion) then the way you are trying to do it.,  Once the variables are setup, they can be used thru out the tool.  Once it works and you create the addin, you can give the .addin file to anyone and they should be able to double click it to install.
