Python post request to Map Service with spatial filter
2710
10-05-2017 09:52 AM
DEVAPP
i have used this script to call a Map Service an retrivethe geometry:
URL = "http://server/arcgis/rest/services/services/MapServer/0/query"
where = "1=1"
fields = "*"
query = "?where={}&outFields={}&returnGeometry=true&f=json".format(where, fields)
fsURL = URL + query
fs = arcpy.FeatureSet()
fs.load(fsURL)
Now i need to request this service with POST method by REST folder and pass it InpputGeometry with Spatial Relationship, so i can load only a subset of data. How i can do this?
There is some example?
JamesCrandall
MVP Frequent Contributor
Edit: Sorry, I misread/misunderstood what you were asking for.  You will want to implement urlib2.
approw[2] is the 'SHAPE@JSON' key of a SearchCursor of the feature class we are intersecting with the map service features.
import urllib, urllib2
#process waterbody features
#FDEP is the authoritative source and steward for this data and is accessed via thier published map service
queryURL = "http://ca.dep.state.fl.us/arcgis/rest/services/OpenData/WBIDS/MapServer/0/query"
params = urllib.urlencode({'f': 'json', 'geometryType': 'esriGeometryPolygon',
       'geometry': approw[2], 'spatialRel': 'esriSpatialRelIntersects',
       'where': '1=1', 'outFields': 'WBID,WATER_TYPE,WATERBODY_NAME,CLASS', 'returnGeometry': 'false'})
req = urllib2.Request(queryURL, params)
response = urllib2.urlopen(req)
print '*** req start ***'
print str(approw[2])
print '*** req end ***'
jsonResult = json.load(response)
for feature in jsonResult['features']:
    wbdy = feature['attributes']['WATERBODY_NAME']
    wbdytype = feature['attributes']['WATER_TYPE']
    wbid = feature['attributes']['WBID']
    wbdyclass = feature['attributes']['CLASS']
    #print wbdy, wbdytype, wbid
    values = {'WATERBODYID': wbid,
              'WATERBODYNAME': wbdy,
              'WATERBODYTYPE': wbdytype,
              'WATERBODYCLASS': wbdyclass
    waterbodieslst.append(values)
data.update({'WATERBODIES': waterbodieslst})
DEVAPP
hi, James,
thanks for your replay. Your response if that I needed and i have correct my script in this way :
desc = arcpy.Describe(m)
xmin = desc.extent.XMin
xmax = desc.extent.XMax
ymin = desc.extent.YMin
ymax = desc.extent.YMax
envelope = '{"xmin":%s,"ymin":%s,"xmax":%s,"ymax":%s}' % (xmin, xmax, ymin, ymax)
line = arcpy.da.SearchCursor(m, ("SHAPE@JSON",)).next()[0]
queryURL = "http://server/arcgis/rest/services/services/MapServer/1/query"
params = urllib.urlencode({'f': 'json', 'geometryType': 'esriGeometryEnvelope', 'inSR':'4326',
       'geometry':envelope,
       'spatialRel': 'esriSpatialRelIntersects','relationParam': 'FFFTTT***', 'outFields': '*','outSR':'4326', 'returnGeometry': 'true'})
but now i would like to create a in_memory feature of this result but
fc = arcpy.CopyFeatures_management(jsonResult, r"in_memory\feature")
copy feature give me errorinstead with arcpy.Feature Set i could.
I can create feature by the result of query Map Service?
