Python loop script to calculate cumulative sum based on another attribute being the same
6217
03-21-2016 08:44 AM
ClintonCooper1
New Contributor III
I am looking for a script that will calculate the cumulative sum of say population (based on a presorted table that I have created) as long as the variable of ID is the same.  So it might look like
IDPOPCUMPOP
1100100
1250350
1150500
2100100
2500600
3150150
3600750
3100850
31501000
this:
JakeSkinner
Esri Esteemed Contributor
Hi Clinton,
Try the following:
import arcpy
from arcpy import env
env.workspace = r"E:\Temp\Python\test.gdb"
table = "Sample"
list = []
#append IDs to list
with arcpy.da.SearchCursor(table, ["ID"]) as cursor:
    for row in cursor:
        list.append(row[0])
del cursor
#remove duplicates
list = set(list)
#update CUMPOP field
for id in list:
    with arcpy.da.UpdateCursor(table, ["POP", "CUMPOP"], "ID = {0}".format(id)) as cursor:
        firstTime = True
        for row in cursor:
            if firstTime:
                row[1] = row[0]
                cursor.updateRow(row)
                newVal = row[0]
                firstTime = False
            else:
                print newVal
                row[1] = row[0] + newVal
                newVal = row[0]
del cursor
WesMiller
Regular Contributor III
Try the Dissolve—Help | ArcGIS for Desktop  tool. You could dissolve based on ID and sum on either or both of your pop fields
JakeSkinner
Hi Clinton,
Try the following:
import arcpy
table = "Sample"
list = []
#append IDs to list
    for row in cursor:
        list.append(row[0])
del cursor
#remove duplicates
list = set(list)
for id in list:
        firstTime = True
        for row in cursor:
            if firstTime:
                row[1] = row[0]
                newVal = row[0]
                firstTime = False
            else:
                print newVal
                newVal = row[0]
del cursor
ClintonCooper1
New Contributor III
Thank you, this works perfectly!!
ClintonCooper1
New Contributor III
just for reference, I found one issue in line 33:
                newVal = row[0]
Should be:
            newVal = row[1]
ClintonCooper1
New Contributor III
Well I need the running cumulative average.  After I run this loop, I need to be able to remove or select all the rows with a value greater than or less than a certain value that I choose for my analysis.
