Python help- changing output file name if name already exists
9379
14
03-24-2017 06:47 AM
TheoFaull
Hi guys and gals,
I have a script which exports a shapefile to a folder. The output file name is 'Properties.shp'. This file is contasntly accessed by a server machine, therefore it has a LOCK file on it.
When I run the script for a second time, it often fails because it detects that and older version of 'Properties.shp' is already sitting in the folder. So when I update this file I have to manually ammend the script to write 'Properties2.shp' as the new output file name to avoid a clash.
Any ideas of how I can get around this? The overwrite = true function won't work as a LOCK file prevents this.
What I want is for the script to rename the output file 'Properties[current_date].shp'
IanMurray
Honored Contributor
I would recommend setting the current date and time to a variable and concatenating it into your file name.
import datetime
import time
Cur_Date =  datetime.datetime.now().strftime("%y-%m-%d-%H-%M")
print "current date and time is " + Cur_Date
Output_Shape = "Properties-" + Cur_Date + ".shp"
print "New shapefile being written will be called " + Output_Shape
arcpy.FeatureClassToFeatureClass_conversion(Sheet1_Layer, CuroProperties, Output_Shape)
IanMurray
Honored Contributor
You can use Arcpy.Exists to check if the dataset already exists and if it does, make the output a concatenation of the current date with the name and file type of your output.
http://stackoverflow.com/questions/311627/how-to-print-date-in-a-regular-format-in-python
TheoFaull
Let's just say I always want the output file name to include the current date (and time), how can I ammend the output part of the code? So far I've managed to import datetime and time and print it:
import datetime
import time
print datetime.datetime.now().strftime("%y-%m-%d-%H-%M")
But what do I write in the output section?
arcpy.FeatureClassToFeatureClass_conversion(Sheet1__Layer, CuroProperties, "Properties.shp" + datetime ???????????
IanMurray
Honored Contributor
import datetime
import time
TheoFaull
I inserted your code into my code and got:
  File "C:\Program Files (x86)\ArcGIS\Desktop10.4\ArcPy\arcpy\conversion.py", line 1694, in FeatureClassToFeatureClass
    raise e
ExecuteError: ERROR 000354: The name contains invalid characters
Failed to execute (FeatureClassToFeatureClass).
IanMurray
Honored Contributor
The hyphens are invalid characters for the shapefile name, replace them all with underscores and it should work fine.
Cur_Date = datetime.datetime.now().strftime("%y_%m_%d_%H_%M")
Output_Shape = "Properties_" + Cur_Date + ".shp"
TheoFaull
Thanks that's brill iamurray
Is there any way I can make the date format like 'Mar_27_2017'
DanPatterson_Retired
... check datetime ...options ie datetime.datetime.now().strftime("%y_%m_%d_%H_%M") can all be rearranged
TheoFaull
OK thanks. Lots of info on that page. I don't think I can set it to output a short text month format however (Jan, Feb, Mar etc.)
patience... it is all there
d.strftime("%A %d. %B %Y")
'Monday 11. March 2002'
