Purpose of the describe object as opposed to native object?
1178
08-26-2014 12:32 AM
MalcolmNunn
New Contributor II
Hi there
I am trying to determine what benefit the describe object has over using the properties of the original object.
Does the describe object simply have all the properties that were present on the original object, plus some additional useful generic properties that are not present on the original objects (eg feature class, raster, etc).
Also, is there a way to retrieve a full list of an Arc objects properties?
Cheers
Mal
MatthewLewis
Hi Mal
I'm assuming your referring to the "Describe Object Properties" aspect of arcpy? e.g
desc = arcpy.Describe("C:/Data/chesapeake.gdb")
if so the basic Describe functions (As shown here‌) are just some of the basic properties you can access. For Example
import arcpy
# Create a Describe object
print "DataType: " + desc.dataType
However you can extend this function depending on the type of object your referencing. The example above used a geodatabase workspace. You could for example desibe a feature class. This would give you access to different properties. For Example
# Create a Describe object from the feature class
desc = arcpy.Describe("C:/data/arch.dgn/Point")
print "Feature Type: " + desc.featureType
print "Shape Type : " + desc.shapeType
Or for a Raster
desc = arcpy.Describe("C:/data/preston.img")
# Print some raster dataset properties
print "Band Count:  %d" % desc.bandCount
print "Compression Type: %s" % desc.compressionType
print "Raster Format:  %s" % desc.format
You can get a full list here. I hope that answers your question and isn't just a waffle
MatthewLewis
Hi Mal
import arcpy
Or for a Raster
MalcolmNunn
New Contributor II
Hi Matthew
Thanks for the response, it does clarify this a little bit.
I think my confusion actually lay in whether object properties could be directly accessed without creating a Describe object. For example, accessing the raster bandCount property from the raster object directly without creating a Describe object.
After a little experimentation I find that this is indeed possible - my problem was that in the method I used of listing datasets then looping through the list, the iterable item was actually unicode and needs to be converted into the correct object first, ie:
import arcpy
arcpy.env.workspace = r"C:\Users\uqmnunn\Documents\Borneo\spatial_data\DataInventoryTool_test"
datasets = arcpy.ListDatasets("*", "Raster")
for d in datasets:
    print("Raster dataset found: %s" % str(d))
    print("Band count:%d" % d.bandCount)
Will return an AttributeError to say that 'unicode' object has no attribute 'bandCount'. However, converting d to a raster object first makes it possible to access raster object properties directly without a Describe object:
     d = arcpy.Raster(d)
So thank you for the explanation of Describe, and now I have clarified my other misunderstanding about accessing object properties without Describe!
Cheers
Mal
