Programmatically get the data source from a lyr file pointing to an Esri GRID format raster uing Python 2.7 and ArcMap 10.5
2626
7
11-16-2018 12:50 AM
MatthewHowe
New Contributor III
I'm trying to get the data source from a bunch of lyr files pointing to various raster formats. Using the lyr.dataSource method on a feature layer after creating a layer object I can get the data source for TIFs fine but Esri GRID format rasters are seen as being directories. My goal is to re-path the lyr files to the same raster that has been copied to another location using the lyr.replaceDatasource method.
  1. import arcpy lyr = r”\\gis\test.lyr”
    layer = arcpy.mapping.Layer(lyr)
    print layer.dataSource
    Runtime error Traceback (most recent call last):
    File "<string>", line 1, in <module>
    File "c:\program files (x86)\arcgis\desktop10.5\arcpy\arcpy\arcobjects\_base.py", line 78, in _get(attr_name, self.__class__.__name__))
    NameError: The attribute 'dataSource' is not supported on this instance of Layer.
Is there a clever way to get the full data source for the lyr file?
DanPatterson_Retired
keep digging
Layer properties—Help | ArcGIS Desktop
layer
(Read Only)
The Describe object of the layer within a .lyr file.
MatthewHowe
New Contributor III
Thanks Dan. I just tested and it gives the path of the lyr file itself and not the path of the data it's pointing to.
keep digging
layer
(Read Only)
MatthewHowe
New Contributor III
Thanks Dan. I think I've sorted.
lyr = r'\\gis\test.lyr'
flyr = arcpy.mapping.Layer(lyr)
for l in arcpy.mapping.ListLayers(flyr):
  if l.supports("DATASOURCE"):
    if l.isRasterLayer:
      print l.dataSource
..returns the data source I need!
good... things are more or less the same in ArcGIS Pro's arcpy
JoshuaBixby
MVP Esteemed Contributor
Please mark a response as Correct if it answers your question.
MatthewHowe
New Contributor III
Man alive, give me chance!
