Problem with inheritance
1096
12-08-2017 04:54 AM
by Anonymous User
Not applicable
Hi everyone. I'm facing a problem trying to extend the FieldMappings class:
class FeatureFields(FieldMappings😞
def __init__(self, feature😞
super(FieldMappings, self).__init__()
When I try do call the constrcutor:
f = FeatureFields(feature)
The terminal give the following errors:
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\arcpy\arcpy\arcobjects\mixins.py", line 960, in __init__
_BaseArcObject.__init__(self)
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\arcpy\arcpy\arcobjects\_base.py", line 47, in __init__
for arg in args))
RuntimeError: Object: CreateObject FeatureFields not valid
What I'm doing wrong?
DanPatterson_Retired
have you check what is needed as arguments _base and mixins?  can't check those lines
Those line numbers may have changed in 10.5.1
currently 960 is NetCDFFilePropertiesMixin
and the _base will fail since the object has to have an arc_object attribute which may mean subclassing isn't permitted or it failed because it wasn't assigned earlier
((arg._arc_object if hasattr(arg, '_arc_object')
but that could be a line number issue
by Anonymous User
Not applicable
Yes, in mixins.py line 960 we have: _BaseArcObject.__init__(self)
Complete code:
class FieldMappingsMixin(object):
   def __init__(self):
      """FieldMappings()"""
      from arcpy.geoprocessing._base import gp_fixargs
   def __iter__(self):
      return iter(self.fieldMappings)
And in _base.py, line 47 we have:
class _BaseArcObject(object):
   _arc_object = None
   def __init__(self, *args, **kwargs):
      """Wrapper for ArcGIS scripting Arc Objects --
      Create a new object instance if no reference is passed in."""
      super(_BaseArcObject, self).__init__()
      self._arc_object = gp._gp.CreateObject(self.__class__.__name__,
         *((arg._arc_object if hasattr(arg, '_arc_object') else arg)
               for arg in args))
      for attr, value in kwargs.iteritems():
         setattr(self._arc_object, attr, value)
      self._go()
