I have set up a simple test script to demonstrate the problem I'm running into:
<SPAN class="comment token">#importing python modules</SPAN>
<SPAN class="keyword token">import</SPAN> arcpy<SPAN class="punctuation token">,</SPAN> time
basePath <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"C:\Users\vincentl\AppData\Local\PythonTesting\Geodatabases\ScratchAddressing.gdb"</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> basePath
addresses <SPAN class="operator token">=</SPAN> basePath <SPAN class="operator token">+</SPAN> r<SPAN class="string token">"\GIS_DBO_Places_Sample"</SPAN>
whereClause <SPAN class="operator token">=</SPAN> <SPAN class="string token">"OBJECTID IN (1)"</SPAN>
<SPAN class="keyword token">for</SPAN> i <SPAN class="keyword token">in</SPAN> range<SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">100</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
start <SPAN class="operator token">=</SPAN> time<SPAN class="punctuation token">.</SPAN>time<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
addSelect <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>SelectLayerByAttribute_management<SPAN class="punctuation token">(</SPAN>addresses<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NEW_SELECTION"</SPAN><SPAN class="punctuation token">,</SPAN> whereClause<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token">#selecting current record</SPAN>
stop <SPAN class="operator token">=</SPAN> time<SPAN class="punctuation token">.</SPAN>time<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Time elapsed: {0}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>stop <SPAN class="operator token">-</SPAN> start<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Output:
Time elapsed: 2.4421534538269043
Time elapsed: 0.2509007453918457
Time elapsed: 0.26900672912597656
Time elapsed: 0.2650105953216553
Time elapsed: 0.2917516231536865
Time elapsed: 0.2583498954772949
Time elapsed: 0.27279186248779297
Time elapsed: 0.2871057987213135
Time elapsed: 0.31418442726135254
Time elapsed: 0.2747483253479004
Time elapsed: 0.2698488235473633
Time elapsed: 0.2711470127105713
Time elapsed: 0.30519843101501465
Time elapsed: 0.30664968490600586
Time elapsed: 0.3076004981994629
Time elapsed: 0.2947726249694824
Time elapsed: 0.3275151252746582
Time elapsed: 0.3086280822753906
Time elapsed: 0.3205225467681885
Time elapsed: 0.32954835891723633
Time elapsed: 0.32260847091674805
Time elapsed: 0.328507661819458
Time elapsed: 0.3341994285583496
Time elapsed: 0.32455968856811523
Time elapsed: 0.3244626522064209
Time elapsed: 0.3398430347442627
Time elapsed: 0.3336300849914551
Time elapsed: 0.3469429016113281
Time elapsed: 0.3484632968902588
Time elapsed: 0.3517005443572998
Time elapsed: 0.3604257106781006
Time elapsed: 0.36439085006713867
Time elapsed: 0.3885536193847656
Time elapsed: 0.44512104988098145
Time elapsed: 0.395768404006958
Time elapsed: 0.3962588310241699
Time elapsed: 0.4052317142486572
Time elapsed: 0.4457588195800781
Time elapsed: 0.4870429039001465
Time elapsed: 0.42713308334350586
Time elapsed: 0.4171907901763916
Time elapsed: 0.4220712184906006
Time elapsed: 0.4343099594116211
Time elapsed: 0.4841780662536621
Time elapsed: 0.4685649871826172
Time elapsed: 0.4868438243865967
Time elapsed: 0.4662456512451172
Time elapsed: 0.5436382293701172
Time elapsed: 0.5267820358276367
Time elapsed: 0.5091872215270996
Time elapsed: 0.5081048011779785
Time elapsed: 0.5297191143035889
Time elapsed: 0.5239181518554688
Time elapsed: 0.5485963821411133
Time elapsed: 0.5876140594482422
Time elapsed: 0.5736618041992188
Time elapsed: 0.5639777183532715
Time elapsed: 0.5830345153808594
Time elapsed: 0.6187348365783691
Time elapsed: 0.5978899002075195
Time elapsed: 0.6382076740264893
Time elapsed: 0.6436002254486084
Time elapsed: 0.6225919723510742
Time elapsed: 0.6568043231964111
Time elapsed: 0.7085685729980469
Time elapsed: 0.6644773483276367
Time elapsed: 0.6723501682281494
Time elapsed: 0.6834757328033447
Time elapsed: 0.6862823963165283
Time elapsed: 0.7144062519073486
Time elapsed: 0.75490403175354
Time elapsed: 0.7380294799804688
Time elapsed: 0.7777352333068848
Time elapsed: 0.782534122467041
Time elapsed: 0.8311202526092529
Time elapsed: 0.7933468818664551
Time elapsed: 0.8011541366577148
Time elapsed: 0.8183913230895996
Time elapsed: 0.8311331272125244
Time elapsed: 0.8553295135498047
Time elapsed: 0.8610031604766846
Time elapsed: 0.9558396339416504
Time elapsed: 0.9203469753265381
Time elapsed: 0.9103479385375977
Time elapsed: 0.9160957336425781
Time elapsed: 0.928046703338623
Time elapsed: 0.950376033782959
Time elapsed: 0.9951839447021484
Time elapsed: 0.9768331050872803
Time elapsed: 0.9877028465270996
Time elapsed: 1.0079317092895508
Time elapsed: 1.0394885540008545
Time elapsed: 1.0345790386199951
Time elapsed: 1.0764164924621582
Time elapsed: 1.0987389087677002
Time elapsed: 1.108257532119751
Time elapsed: 1.114212989807129
Time elapsed: 1.1997053623199463
Time elapsed: 1.154165267944336
Time elapsed: 1.1690573692321777<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
If SelectLayerByAttribute_management is called multiple times, each successive call will take longer and longer. Is there anything I am doing wrong?
