Problem running arcpy.CopyFeatures using arcpy.da.SearchCursor
2338
6
04-22-2014 06:46 AM
yonatanrubinstein
New Contributor III
Hi, I'm trying to run the following script using python that uses the 10.1 introduced arcpy.da.SearchCursor (with a group by sql clause) to run over a feature layer, select two features with the same field value (hence the group by), export the current features to an outside feature layer, and then calculate a route (using network analyst) between the two point.
The PROBLEM(for now, at least):
when the script runs the arcpy.CopyFeatures, the script fails. I suspect that it is due to the the input features - that row is not a valid input feature. But there I'm stuck, what should I put instead? Am I right in the diagnosis? what can I do to solve it?
Thanks.
 import arcpy  # Check out any necessary licenses arcpy.CheckOutExtension("Network")   # Script arguments Field_To_Group_By = arcpy.GetParameterAsText(0) if Field_To_Group_By == '#' or not Field_To_Group_By:     Field_To_Group_By = "myID" #" # provide a default value if unspecified  Input_Point_Layer = arcpy.GetParameterAsText(1) if Input_Point_Layer == '#' or not Input_Point_Layer:     Input_Point_Layer = "D:\\Projects\\A\\MyDefaultGDB.gdb\\MyDefaultInput" # provide a default value if unspecified  # Local variables: FTGB = Field_To_Group_By Add_Locations_Output_Layer = FTGB  Solved_Layer = Add_Locations_Output_Layer Routes = Solved_Layer route__Value_ = Routes Route__Name___2 = route__Value_ Route__Name___3 = Route__Name___2 totals__2_ = Route__Name___3 Solve_Succeeded = Add_Locations_Output_Layer Value = Field_To_Group_By BasePointsResult = "D:\\Projects\\A\\BasePoints.gdb\\" net_ND = "D:\\Projects\\A\\MyRoute.gdb\\net\\net_ND" totals = "D:\\Projects\\A\\SumsOfRoutes.gdb\\totals" Make_Route_Result_Layer = "Route"  count = 0 field1 = "myID" sql = [None,"GROUP BY myID,  OBJECTID"] currObj =  arcpy.da.SearchCursor(Input_Point_Layer,field1,sql_clause=sql)  try:     for row in currObj:         rowBasePoint = BasePointsResult + "basePoints_" + str(int(row[0]))         print count         # Process: Make Route Layer         arcpy.MakeRouteLayer_na(net_ND, "Route", "Seconds")#, "USE_INPUT_ORDER", "PRESERVE_BOTH", "NO_TIMEWINDOWS", "", "ALLOW_UTURNS", "Oneway", "NO_HIERARCHY", "", "TRUE_LINES_WITH_MEASURES", "")         print "MakeRouteLayer"          print row         # Process: Copy Features - create BasePoints         arcpy.CopyFeatures_management(row, rowBasePoint )#, "", "0", "0", "0")         print "basePoints_" + str(int(row[0]))         print "Copy Features -basepoints"          # Process: Add Locations         arcpy.AddLocations_na(Make_Route_Result_Layer, "Stops", row, "Name # #;Attr_Length # 0", "5000 Meters", "", "Roads SHAPE;net_ND_Junctions NONE", "MATCH_TO_CLOSEST", "APPEND", "SNAP", "30 Meters", "EXCLUDE", "Roads  #;net_ND_Junctions #")         print "Add Locations"          # Process: Solve         arcpy.Solve_na(Add_Locations_Output_Layer, "SKIP", "CONTINUE", "")          # Process: Select Data         arcpy.SelectData_management(Solved_Layer, "Routes")
JoshuaChisholm
Occasional Contributor III
Hmmm, that's tricky. Maybe the Select_analysis would work better:
sql = '"' + field1 + '"' + ' = ' + str(int(row[0])) arcpy.Select_analysis(Input_Point_Layer, rowBasePoint,sql)
If that doesn't work, I might you might need a different sql statement (because you're using a '.gdb'). Try this too:
sql = '[' + field1 + ']' + ' = ' + str(int(row[0])) arcpy.Select_analysis(Input_Point_Layer, rowBasePoint,sql)
Let me know how it goes.
JoshuaChisholm
I think your diagnosis is correct. You'll have to create a feature layer and export that instead of the row. Assuming "myID" is unique, this should work:
sql = '"' + field1 + '"' + ' = ' + str(int(row[0])) #use this line if myID is a number (and remove the other line)
sql = '"' + field1 + '"' + ' = ' + "'" + str(int(row[0])) +"'" #use this line if myID is a text (and remove the other line)
arcpy.MakeFeatureLayer_management(Input_Point_Layer, "selection", sql)
arcpy.CopyFeatures_management("selection", rowBasePoint)
(insert this code where the arcpy.CopyFeatures_management line is)
Let me know how it goes. Good luck!
yonatanrubinstein
New Contributor III
Hi Joshua, thanks for answering.
I did as you wrote (in my case the myID is a number), but it made a feature class consisting of all the features in the original fc, and not just the ones selected by the "row". Any IDEAS?
JoshuaChisholm
markdenil
Simply put, you should never try to export or make layers or copy feature classes inside a cursor.
That is not what cursors are for.
Exporting a geometry object is something else, but that is far to complex a solution for your need.
Use the search cursor to get a list of the unique vaues in the myID field
myIdList = []
cur = arcpy.da.SearchCursor(Input_Point_Layer,field1)
for row in cur:
    myID = row[0]
    if myID not in myIdList:
        myIdList.append(myID)
now loop through the list; making layers of, and copying out features with, each myId value:
for my in myIdList:
    outLayer = "outLayer"
    if arcpy.Exists(outLayer):
        arcpy.Delete_management(outLayer)
    newFC = r"%s\out_%s" % (pathVar, my)
    if arcpy.Exists(newFC):
        arcpy.Delete_management(newFC)
    where = "\"myID\" = '%s'" % (my)
                                      outLayer,
                                      where)
    CopyFeatures_management(outLayer, newFC)
yonatanrubinstein
New Contributor III
Hi Joshua , Sorry for the late reply.
Your Idea worked beautifully, when I used Select_Analysis instead of CopyFeatures.
Thanks!
yonatanrubinstein
New Contributor III
myIdList = []
for row in cur:
    myID = row[0]
for my in myIdList:
                                      outLayer,
                                      where)
Mark, I know that cursors "are not meant" for this, but a. it works. b. I didn't find any other way, I would appriciate it if you show me a different way. The two loops you presented are not good enough - I want a single loop, as I loop over a table of 150,000 lines and want it to be quick...
