Outputting same name as input using Copy Features
2173
11
07-08-2020 09:21 AM
AliciaShyu
I'm writing a script that has 30+ layers and a boundary layer. I need to copy all the layers that intersect with the boundary to a GDB.
I have the following for the "Select layer by location" tool
# Select by location all layers that intersect with AirBound and copy selection to GBD
= aprx.listMaps("Test")[0]
for layer in m.listLayers():
    if layer.name != AirBound:
        arcpy.SelectLayerByLocation_management (layer, "INTERSECT", AirBound)
        print (arcpy.GetMessages())
Is there any way to use "Copy Features" tool  where the output name is the same as the input name?
Thanks!
JoshuaSharp-Heward
Interesting, let's make a slight tweak to that then:
outname = os.path.join(GDB, layer.name)
arcpy.CopyFeatures_management(layer, outname)
just to be sure it's writing to the geodatabase that we want it to.
JoshuaBixby
A layer name doesn't have to match the data set name, so what name are you wanting to use?
Where do you want to copy the features to exactly?
AliciaShyu
The features would go into the new GDB. I want to use their original names from SDE
I'm trying to avoid creating 30+ output names using variables.
Sorry, should have copy the entire script.
import arcpy, os, sys, math, time, smtplib
arcpy.env.orverwriteOutput = True
# Project Variables
aprx = arcpy.mp.ArcGISProject ("CURRENT")
GDB = "\\\\cdmgis\\d$\\Scripts\\Python\\AirportFTP\\Airport.gdb"
AirportBound = "\\\\cdmgis\\d$\\Scripts\\Python\\AirportFTP\\AirportBoundary.gdb"
AirBound = AirportBound +"\\CloseGISBoundary"
ExtAirBound = AirportBound + "\\ExtendedGISBoundary"
# # Delete old GDB and creates new one
if arcpy.Exists (GDB😞
    arcpy.Delete_management (GDB)
    arcpy.AddMessage(arcpy.GetMessages())
if not os.path.exists (os.path.dirname(GDB)):
    os.mkdir (os.path.dirname(GDB))
arcpy.CreateFileGDB_management (os.path.dirname(GDB), os.path.basename(GDB))
arcpy.env.workspace = GDB
JoshuaSharp-Heward
Are the layer names the same as the names in the SDE? If so the following line should do the trick:
arcpy.CopyFeatures_management(layer, layer.name)
just below the selection.
AliciaShyu
Thanks but that didn't work. Got the error below
ERROR 000733: Output Feature Class: Same as input Input Features
Failed to execute (CopyFeatures).
JoshuaSharp-Heward
AliciaShyu
That worked!! Thank you so much Josh!!
JoshuaSharp-Heward
No worries, glad that worked out!
JoeBorgione
I took the liberty of copying and pasting your code into the syntax highlighter.  Easier to read and note issues with line numbers...
# Project Variables
if arcpy.Exists (GDB):
m = aprx.listMaps("Test")[0]
        print (arcpy.GetMessages())‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
JoeBorgione
I'm a little confused with GDB; seems like you are all over the map checking for it, deleting it, creating it etc: lines 11 through 17.
