Needing to automate the task of uploading hunderds of KMZ files to my ArcGIS Online account.
1022
08-27-2020 09:27 AM
by Anonymous User
Not applicable
I recently converted a bunch of registered tif images to kmz format and now need to push these to AGOL as seperate files. Any ideas on how to automate this process?
by Anonymous User
Not applicable
Below is the python code I ended up using to accomplish this. Thanks for the help!
import os
from arcgis.gis import GIS
path = r'PATH' # the folder where the .kml and .kmz files are stored
# List all .kml and .kmz files in the folder
KMLs = []
for root, dirs, files in os.walk(path):
    for file in files:
        if '.kml' in file or '.kmz' in file:
            KMLs.append(os.path.join(root, file))
for KML in KMLs:
    print(KML)
gis = GIS("https://arcgis.com", "USERNAME", "PASSWORD", verify_cert=False)
# Add the .kml and .kmz files
Items = []
for KML in KMLs:
    kml_properties = {
        'type': 'KML',
        'typeKeywords': os.path.split(KML)[1]
    data_file_location = KML
    # Add item to portal
    add_KML = gis.content.add(item_properties = kml_properties, data = data_file_location)
    # Share item to everyone
    add_KML.share(everyone = True)
    Items.append(add_KML)
Items
for item in Items:
    print(item.title + ": " + "https://OrganizationName.maps.arcgis.com/home/item.html?id=" + item.id)
BruceHarold
Hello Anthony, Data Interoperability extension has a transformer called ArcGISOnlineConnector that would let you batch this upload.
by Anonymous User
Not applicable
Hi Anthony,
If you're looking for something more on the Python side, then the easiest way I can think of would be to use the ArcGIS API for Python. We can iterate through all the KMZ files and add them as items to your ArcGIS Online content. The specific method would be the add operation in the arcgis.gis.ContentManager class arcgis.gis module — arcgis 1.8.2 documentation . KMZ files are a supported file format for ArcGIS Online (a full list can be found here), so you should be able to do this directly.
Here's a sample:
import arcgis
gis=GIS("https://arcgis.com", "username" , "password")
properties={'title':'myKMZ', 'type':'KMZ','description':'myDescription','tags':'myTags'}
item = gis.content.add(item_properties=properties, data=r"\path\to\myKMZ.kmz")
To iterate through a folder, there is a sample script that can provide a solid starting point: Publishing SDs, Shapefiles and CSVs | ArcGIS for Developers
We can just substitute KMZ files wherever we see SD files in the above sample, and we should be good to go.
Hope this helps!
Best,
Calvin
by Anonymous User
Not applicable
import os
KMLs = []
    for file in files:
for KML in KMLs:
    print(KML)
Items = []
for KML in KMLs:
    kml_properties = {
        'type': 'KML',
Items
for item in Items:
by Anonymous User
Not applicable
I noticed publishing KML files using the script I provided doesn't give a service URL. If I upload a kml manually through the add items tool in arcgis online then it does give it a service url. Any ideas?
by Anonymous User
Not applicable
Jake Skinner‌
Do you have any ideas on my issue above with service url's not being generated if I upload my kml files through python?
