Hello there.
We have a vast amount of mxds, and my goal is to search that entire drive and find out which mxds have layers that are referencing a specific source path. Then I would like to know how to replace that specific source path with the new source path.
I would presume that this would require a python script. All of the scripts I've found so far require that I know the name of the particular mxd in question. I'm trying to scan all of the mxds in the drive.
Kirsten
Here is how to loop through your drive, using Python's os module, to find all the mxds:
import os
for root, dirs, files in os.walk('C:/junk'):
for file in files:
if os.path.splitext(file)[1] == '.mxd':
print 'It is an MXD!'
...from here.
Thanks for that. So I now how to get a list of mxds, but I need to know which ones have data layers that are pointing to a certain path. Then I need to replace the paths in those mxds with a new path.
Refer to the arcpy.mapping help.
Oh, thanks for the suggestion to move it to Python. I've never posted to this forum before, so I was unaware.
According to the Help you should be able to use arcpy.da.Walk to loop through the mxd files in a folder (and subfolders):
import arcpy import os workspace = r"D:\Xander\GeoNet" walk = arcpy.da.Walk(workspace, datatype="Map") for dirpath, dirnames, filenames in walk: for filename in filenames: mxdfile = os.path.join(dirpath, filename)
... but when I tried it didn't give me any result.
However, you can use:
import arcpy import os import fnmatch directory = r"D:\Xander\GeoNet" pattern = "*.mxd" for root, dirs, files in os.walk(directory): for filename in fnmatch.filter(files, pattern): mxdfile = os.path.join(root, filename) print "mxd file: {0}".format(mxdfile) mxd = arcpy.mapping.MapDocument(mxdfile) dfs = arcpy.mapping.ListDataFrames(mxd) for df in dfs: print " - data frame: {0}".format(df.name) for lyr in arcpy.mapping.ListLayers(mxd, data_frame=df): print " - layer name: {0}".format(lyr.name)
... to loop through the mxd's, the data frames and layers within the dataframes.
To update any datasource I recommend you to read this page of the Help: ArcGIS Help (10.2, 10.2.1, and 10.2.2)
